Author Topic: 4-Spd vs. Auto Consoles  (Read 1311 times)
Offline troutstreamnm
« on: February 22, 2007 - 10:00:59 PM »
Is there any difference between a 4-speed and auto console (shape of main body) on a 71 Challenger?  Thanks for any help
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
Re: 4-Spd vs. Auto Consoles
« Reply #1 on: February 22, 2007 - 10:26:47 PM »
Offline 70challengerrt
« Reply #2 on: February 23, 2007 - 04:25:37 AM »
Yes. In my 70 I used a automatic console. When you buy the correct top plate you should get a template for cutting the bottom notch for the shifter. When done with the template and the top plate there is no way to tell them apart. I got mine off ebay plate and template together. It also a lot cheaper buying the auto console.
« Reply #3 on: February 23, 2007 - 05:10:47 PM »
Thanks a bunch.  This is exactly what I needed  :worshippy
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
« Reply #4 on: February 23, 2007 - 05:36:58 PM »
Here are some pics for you Grec. They are the template, and my finished console (ignore the top by the shifter mine was busted). I put tape on the console where I was going to cut it then put the template over it lining up the screw holes and traced it. I used and air body saw and die grinder to cut and smooth it out. But i'm sure the probably a couple of thing that can cut it well. I will try to trace it and send you a copy. Keep in mind you still need the top plate.
Todd
Offline Grec
« Reply #5 on: February 24, 2007 - 02:45:59 PM »
Many thanks.
And yeah... got the top plate already. This is the final piece. :-)
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
« Reply #6 on: February 26, 2007 - 05:31:13 PM »
I sent the templates today. Any questions let me know.
Good Luck
Todd
« Reply #7 on: February 26, 2007 - 06:40:57 PM »
Thanks Todd.  :2thumbs:
