Author Topic: interesting looking exhaust valves  (Read 2185 times)
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« on: February 23, 2007 - 01:01:53 AM »
When my father was taking apart his engine, we noticed that the exhaust valves for cylinders #5 and #8 did not have any carbon on them, but all of the other valves (including intakes) had a lot of carbon deposited on them.
What could have caused this?
Offline moper
Re: interesting looking exhaust valves
« Reply #1 on: February 23, 2007 - 10:07:48 AM »
Can you post a pic?
Offline Jacksboys
« Reply #2 on: February 23, 2007 - 01:10:59 PM »
sure, here you go.
1st- driver's side head - #5 clean  :clueless:
2nd- Pass. head - #8 clean  :clueless:
maybe 10 miles on the motor
« Last Edit: February 23, 2007 - 01:12:46 PM by jacksboys »
sleepychallenger
« Reply #3 on: February 23, 2007 - 01:29:39 PM »
wow. thats cool!
Offline Harkonnen
« Reply #4 on: February 23, 2007 - 03:35:55 PM »
Is it just the light or is the #8 at the passenger side oily ?
« Reply #5 on: February 23, 2007 - 04:11:32 PM »
I noticed that too.  :22yikes: That would NOT be a good sign.  :grinno:
« Reply #6 on: February 23, 2007 - 05:15:01 PM »
Has 10 miles on it and had to take it apart?  Kinda looks like a bad seal on the head gaskets to me, in a couple of areas on both heads.
Hows the plugs and did you do a compression test before tear down?
sleepychallenger
« Reply #7 on: February 23, 2007 - 06:16:58 PM »
i didnt even notice till you said. uh oh  :walkaway:
Offline Jacksboys
« Reply #8 on: February 24, 2007 - 12:03:26 AM »
I think that he just got it dirty when he was removing the heads.  There were no signs of oil on the plugs.  The interesting part of the plugs was that all of them looked "good to lean" except for the #1 plug which looked real rich.
This is the motor that he was having a ticking noise from the valve train that would not stop.  He found out that there was a plug missing at the oil filter and it was not pumping oil very well.  The motor came out and he checked the rear main only to find that it was badly worn.  :banghead:
I think the picture looks deceiving because I person, the gaskets looked like they had a good seal.
He did not do a compression test.
« Reply #9 on: February 24, 2007 - 12:37:39 AM »
ok so you are running a dual plane intake & 1 side of the carb is running lean causing the exhaust valves to run far too hot
Offline Jacksboys
« Reply #10 on: February 24, 2007 - 12:59:51 AM »
yep a dual plane intake
I never would have thought of the carb...  :clueless: ...Which side of the carb would need to be changed?
« Reply #11 on: February 24, 2007 - 12:13:35 PM »
well you need to know which side each head was removed from ,the 2 center valves on one head & the 2 outer valve on the other head will be on one plane either upper or lower & once you determine which plane is lean you can tell which side of the carb is running too lean & feeding the plane which is lean
Offline Jacksboys
« Reply #12 on: February 24, 2007 - 08:56:35 PM »
okay, thanks for the info
Offline GoodysGotaCuda
« Reply #13 on: February 25, 2007 - 07:20:16 AM »
I would think the oil is from disassembly as well. You fired a new motor without a oil pressure gauge?  :nono:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Jacksboys
« Reply #14 on: February 25, 2007 - 07:55:30 PM »
It had a pressure gauge at the filter, not at the top of the block. That gauge was reading 60 psi when cold, so the high volume pump had to be moving a bunch of oil.  I suggested to add another gauge at the top of the block and then we found the problem.
« Last Edit: February 25, 2007 - 07:59:26 PM by jacksboys »
