Author Topic: 8 3/4 axle seals Where to buy?  (Read 4065 times)
« on: February 23, 2007 - 01:28:08 PM »
Planning on pulling the axles out of my 8 3/4 to grease/inspect & figure I will need some new axle seals.
After a lot of searching other than complete bearing kits and some overpriced eBag offerings, emailed the local dealership & have come to the conclusion that no one sells just the seal.
Thought I had something at Advance Auto based on the description but other searches call their part (BCA # 5126) a pinion seal. Could the pinion seal & axle seal be the same?
    Sooooo any ideas?
Thanks  Wade
Offline Killer_Mopar
Re: 8 3/4 axle seals Where to buy?
« Reply #1 on: February 23, 2007 - 02:10:12 PM »
Never saw just the seals by themself, always with a bearing kit. The pinion seal isnt the same. Dont know if you need them, but the gaskets for the axle are on clearance at mancini......
http://chucker54.stores.yahoo.net/axhoga834da6.html
« Reply #2 on: February 24, 2007 - 12:31:30 AM »
I have never had a problem buying the inner axle seals , I do not have the # handy but I can get it if needed , the local parts store carrys them for about $8
« Reply #3 on: February 24, 2007 - 07:39:27 AM »
Picked up some part #s from this site http://www.geocities.com/motorcity/flats/1549/index3.html
& found these listed
Advance Auto
Outer seal SKF 19000  $9.99
Inner seal SKF 15460 $9.29
Flange gasket Felpro 55032 $1.48
Housing Felpro RDS6583  $3.88
NAPA
Outer seal NOS19000 $14.79
Inner seal NOS12590  $10.99
Flange gasket J27962 $1.69
Housing NGAP27930  $4.99
Offline vinb
« Reply #4 on: February 24, 2007 - 08:06:17 AM »
I think the part # is 8695S, It should be a National seal part #. approx. $8.00 ea.
any auto store should be able to get them in 1 day...
Offline matt63
« Reply #5 on: February 24, 2007 - 08:08:46 AM »
If you have the p/n you can always go to an industrial bearing or power transmission shop for these parts.
Matt in Edmonton
'68 Valiant
Offline Pentastar Pete
« Reply #6 on: February 27, 2007 - 01:30:26 PM »
Any chance anyone would have the Mopar Part # for the outer seals???
bullitt99: the part #'s for the seals:
looking at the exploded view of the rear in the Restoration Guide
Page 96 for 8 3/4 rear:
1. Retainer or Axle Flange 2. Oil Seal  3. Flange Gasket
Are you ref. to the first OIL SEAL  (3) as the OUTER SEAL???
On the Right side, they show an adjuster. Does that have to be replaced??
Any advice on this adjuster would be helpfull.
Never attempted seals before.
Thanks
74 Rallye Challenger
73 Rallye Challenger
68 Charger RT
« Reply #7 on: February 27, 2007 - 03:03:09 PM »
2challengers2, This is my first time around and just getting started so someone else needs to answer your tecnical questions. These are the OE part numbers from http://www.geocities.com/motorcity/flats/1549/index3.html
Axle inner seal 4796698
Axle outer seal 2404216
Axle flange, foam 2070933
« Reply #8 on: February 27, 2007 - 03:42:48 PM »
Thanks Bullitt99, Called a local Dodge Dealer. These numbers are good and the parts are still available...
Thanks
Pete
68 Charger RT
« Reply #9 on: February 27, 2007 - 11:53:34 PM »
THe outer seals are much less important , they are just a grease seal to keep grease in the brgs & DIRT OUT , the inner seals do most of the work keeping the oil in the diff
