Cam suggestion
Author Topic: Cam suggestion  (Read 6082 times)
Offline Stacked440
Cam suggestion
« on: February 23, 2007 - 05:56:08 PM »
Well, my cam is WAY to hot for my build in my 440...Anyone suggest any cams slightly hotter than stock but very mild? :clueless:
-Kyle-
nivvy
Re: Cam suggestion
« Reply #1 on: February 23, 2007 - 06:11:00 PM »
A lot of people recommend the Mopar .484 cam.....but probably wouldnt go over the .509 cam,,,,for a mild street cam!
I like roller cams myself...more lift with less duration for streetability.....I think Chyrco likes the engle K54 cam
GRIND                   LIFT        LIFT         LIFT          DURATION
NUMBER                 1.6           1.5         at Cam         @ .050”
K-54HYD      .501”      .470”        .313”                214
K-56HYD      .538”      .504”        .336”                224
K-58HYD      .549”      .514”        .343”     230
What is your current cam specs?
if you like i can email you engles complete list!
« Last Edit: February 23, 2007 - 06:14:43 PM by StrOkEr »
Offline Dustu
Re: Cam suggestion
« Reply #2 on: February 23, 2007 - 06:15:45 PM »
Comp Cams Extreme Energy 280 to 290 adv.  dur. .500 or less lift.
Offline Stacked440
Re: Cam suggestion
« Reply #3 on: February 23, 2007 - 06:21:54 PM »
I threw away the box that had the cam specs on it about a month ago :pullinghair:  But If i remember right it was a .510?  If I go with a roller cam do I gotta change my valve train springs, lifters, rocker arms?
-Kyle-
nivvy
Re: Cam suggestion
« Reply #4 on: February 23, 2007 - 06:31:22 PM »
What are you looking for in a cam?? what intake you running / transmission / gears???
Offline Stacked440
Re: Cam suggestion
« Reply #5 on: February 23, 2007 - 06:35:08 PM »
I want it to be a good street cam.  I'm running an Edelbrock high-rise intake, a 4-spd tranny, and a 3.21 8 3/4 rear end.  Something that will give me halfway decent fuel economy as far as a 440 goes.  Basically, not a drag cam, something for a cruiser that can get up and go...i really don't know how else to explain what i'm looking for :lol:
-Kyle-
nivvy
Re: Cam suggestion
« Reply #6 on: February 23, 2007 - 06:43:11 PM »
well if your running a high rise edelbrock it is probably the Torker 2 or performer rpm which I believe is rated at 2500-6500 rpm....so you will want a cam in that power range to match...
why do you think your .510 lift cam is too much...??
Mopar .484 cam specs                  CL        lift                      rpm range
*P5007697  284/284  241/241  56  114  .484/.484  P3690933  2200-5900  Street/Improved driveability
Mopar .509 cam specs
P5007698    292/292  248/248  64  114  .509/.509  P5249848  2600-6000  Street/Improved driveability
Offline Stacked440
Re: Cam suggestion
« Reply #7 on: February 23, 2007 - 06:56:23 PM »
I wish I would have kept the box...I asked someone who builds motors for racing and he said the cam was fairly hot for a street car.  AG...i really wish i kept the box I could give you exact specs on it, I know it was a comp cams extreme 2 or something like that. :dunno:
-Kyle-
nivvy
Re: Cam suggestion
« Reply #8 on: February 23, 2007 - 07:05:39 PM »
There is a cam on comps website with .510 lift...it is the same as the mopar .509 cam but has a centerline of 108* as opposed to mopar 114*
nivvy
Re: Cam suggestion
« Reply #9 on: February 23, 2007 - 07:11:20 PM »
I run a solid roller comp cam .627 lift with 1.7 roller rockers duration is 254 @ .50 - 110 CL
no problems street driving for me....  :burnout:
I would get some more suggestions.. I personally think the comp .510 is fine...dont like the 108* centerline though!
or you can just get the .484 cam buy 1.6 rockers and get a little more lift of .516 and have a 114* CL  ...
Offline Stacked440
Re: Cam suggestion
« Reply #10 on: February 23, 2007 - 07:45:29 PM »
the only problem is I THINK it was a .510, i'm not sure by any means...blast...i'm getting middle age memory loss at 19!!!!! :faint:
-Kyle-
Offline Stacked440
Re: Cam suggestion
« Reply #11 on: February 23, 2007 - 10:37:24 PM »
Will the .484 lift mopar cam give me a stable idle?
-Kyle-
Re: Cam suggestion
« Reply #12 on: February 24, 2007 - 12:36:29 AM »
not really , the Mopar cams have more duration / lift than similar engle grinds , you can have a .508 lift Engle with less duration & better idle quality
Offline Stacked440
Re: Cam suggestion
« Reply #13 on: February 24, 2007 - 09:04:03 AM »
I plan on staying with a hydraulic flat tappet cam, but I don't want to have to babysit the throttle just to keep it running.
-Kyle-
Offline Stacked440
Re: Cam suggestion
« Reply #14 on: February 25, 2007 - 01:00:38 PM »
I pulled the cam and it had the part number on the back! :woohoo:  This cam look good?  I want it to at least Idle at low RPMs :-\
http://www.compcams.com/Technical/Search/CamDetails.asp?PartNumber=21-225-4
« Last Edit: February 25, 2007 - 01:02:14 PM by Stacked440 »
-Kyle-
