Pushrod length
Author Topic: Pushrod length  (Read 855 times)
Offline basement
Pushrod length
« on: February 27, 2007 - 07:48:15 AM »
Can someone please enlighten me on pushrod length. I see people talking about changing pushrod length, but why? Wouldn't this essentially change or effect cam lift? Would you also run the risk of running a valve into the top of a piston? When would you want to change to the length?
nivvy
Re: Pushrod length
« Reply #1 on: February 27, 2007 - 08:45:21 AM »
I just changed roller rockers from 1.6 to 1.7 ratio and I need to change my pushrod length...I believe it is because of the different mfg of the rockers....I actually need to go a little smaller! I have a 499 StROkEr ....
Offline moper
Re: Pushrod length
« Reply #2 on: February 27, 2007 - 10:18:06 AM »
Pushrods do not effect the amount of lift produced by the cam lobe. However, if the angles are off too far, the "effective lift" (as measured off the valve spring retainer) can be shrunk. The worse the angles, the less effective lift. Also, having things moving properly means less wear on parts, less oil use, and more power produced from that combination. When it's all said and done, you want the rocker's tip to be at 90° to the valve stem and centered at mid lift on the cam. To get this, you adjust the height of the rocker shafts with shims, or special shaft stands and retainers, or you change the pushrods. After a complete rebuild, things like decking the block and heads, different gaskets, different camshaft base circle diameters, valve jobs, and aftermarket part's specs all combine to change the factory pushrod length needs. Most times, shorter ones will be needed. Sometimes, longer ones are needed to keep the rockers' ajusters at a safe spot, or to keep hydraulic lifters preloaded properly. Pushrods are one of those things most guys take for granted and "assume" are fine. The right ones mean power and stability...The wrong ones mean it runs, and hopefully doesnt hurt anything else.
