Author Topic: Ralley Tach Wiring Question  (Read 2207 times)
Offline nosrettaw
  • 1974 'Cuda
« on: October 02, 2003 - 06:51:09 PM »
I know the tach gets hooked up to the neg. - side of the coil but my question is which wire is it? There is a light tan wire that come out the same loom as the pos. and neg leads for the coil that is not hooked up. is that the Wire?? I don't want to just try it cause i don't want to burn anything up. If you know for sure that is the wire i will try it. But there is only those 3 wires that come out there. the other 2 go to the coil + & - ??
Any help would be greatly appreciated...
Thanks
Steve
Fried Fish Smells Like Burning Rubber !!
Re:Ralley Tach Wiring Question
« Reply #1 on: October 03, 2003 - 01:11:44 AM »
Sorry I don`t have a 74 wiring scematic but the 70 used a grey wire
« Reply #2 on: October 03, 2003 - 05:36:42 PM »
 ;) If you want to play it safe, you could do what I did. I ran a wire from the "-" side of the coil into the dash gauges. I kind of hid it behind the harness. Be sure to use wire for engine compartments though, you don't want any meltdowns.
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
« Reply #3 on: October 07, 2003 - 08:22:52 PM »
Steve- checked a 73 barracuda manual- it doesn't show any tan wires anywhere in the engine area.
if yours had a tach- it should be a grey wire that then goes to a grommet in the firewall by the regular wires- this then goes to the tach.
it was always a separte grey wire.
maybe someone else ran the tan wire- try to follow it to where ever it goes.
John mAC
Offline nosrettaw
  • 1974 'Cuda
« Reply #4 on: October 08, 2003 - 11:34:31 PM »
Those 3 wires are all taped together + & - for the coil and the thought to be tan wire. looks like a factory taping job. but i peeled the tape back and it looks grey. the end is also a male spade connector. that is the wire that goes to the neg. side then????
thanks steve
Offline 71 DEPUTY
    • Cardomain
« Reply #5 on: October 16, 2003 - 07:51:31 PM »
HI sTEVE- haven't checked back here for awhile- yes that is the - tach wire.
and it goes to the spade connection on the back of the tach.
there should be a red wire for power when the key is on.
