Author Topic: 1st rebuild  (Read 1247 times)
Offline dmk67
1st rebuild
« on: February 28, 2007 - 02:53:14 PM »
iam beginning my first rebuild and need help. what im working with is a 75 440blk,906heads or452heads i want to send the blk and heads to the machine shop for prep work and install all componets myself what should i ask the machine shop to do? the car is basicly going to be a street car but i would like to kick some corvette butt!!!any ideas on vavle size, cam,stock bore maybe 10.5 to 1compression lets share in the fun ,nothing to exotic. :dogpile:
nivvy
Re: 1st rebuild
« Reply #1 on: February 28, 2007 - 03:57:41 PM »
Well no higher than 10 to 1 compression with the Iron heads..hardened seats in the exhaust as well !!! as far as work on the heads how much HP do you want ??? stick or automatic ... what gears etc ...
Offline 70challengerrt
Re: 1st rebuild
« Reply #2 on: February 28, 2007 - 05:02:19 PM »
I am building basically the same motor. Here are some suggestions I had made.
http://www.cuda-challenger.com/cc/index.php?topic=28838.0
Its also in the same topic under buildup???
Offline dmk67
Re: 1st rebuild
« Reply #3 on: February 28, 2007 - 05:39:09 PM »
the engine is being built for a auto i dont have a rear end yet
nivvy
Re: 1st rebuild
« Reply #4 on: February 28, 2007 - 06:19:55 PM »
Well I put ALL my info on paper before I purchased parts...Then I purchased them.. then I found an engine builder and he had other Ideas I liked and sent a lot of it back and went BIGGER ... lol  :burnout:
1st thing I did was figure out what I was gonna do with the car and went from there!
Re: 1st rebuild
« Reply #5 on: March 01, 2007 - 10:07:33 AM »
[/quote]
Re: 1st rebuild
« Reply #6 on: March 01, 2007 - 10:12:02 AM »
I would keep it around 9.6:1 with iron heads , I use the Speed Pro 2355f piston , this combo will give ideal compression using either head
 I can help with cam choice with more info , first solid or hyd , what RPM range for the powerband ? what converter / intake / carb do you want to use etc
 have the block cleaned & bored , 440 Source has sroker kits for approx the cost to fix what you have so you may want to look into that
Offline dmk67
Re: 1st rebuild
« Reply #7 on: March 01, 2007 - 11:08:27 AM »
i am still gathering info so all of your questions are giving me a direction to go i would like to be able to drive it to shows so nothing to wild.hyd cam idont know anything about 440source i need to spend more time reading and less time typing  :newbie:
Re: 1st rebuild
« Reply #8 on: March 01, 2007 - 11:13:42 AM »
I have built some solid cam engines that sound & look stock but really turn on when you get on them , perfectly drivable
Offline moper
Re: 1st rebuild
« Reply #9 on: March 02, 2007 - 06:27:50 AM »
First, I would say  prior to dropping off the parts...Get yourself a disposable camera if you dont have digital. As you tear it apart, take pictures of everything the way it was BEFORE you took it apart. Take one of the brackets/pulleys, one after the valve covers and intake are removed, etc. Two cameras should do it, and you wont get crud all over a nice camera...lol When it's all apart, and you have "references", do some online research on how those aprts do waht they do, and more precisely, how the numbers are calculated and why. The reason behind the research  is it makes you aware of what choices you'll need to make, and why the machine shop needs to do what it does. It will clarify some common confusions too. Like that compression ratio question.
If you are running open chamber iron heads, you will not want "10.5:1" in it. However....The piston companies will sell you a "10.1:1" piston, that will end up at a lower static ratio than 10.5:1 in your engine, and it will work fine. Ask questions. Keep asking "why?". If you cant get an answer you understand, ask again. If you cant get an answer other than "trust me", find another shop. Last, if you are planning to assemble yourself, you will need some tools. Not basic hand tools. Measuring stuff. So leave room in the budget for it...
There's no greater feeling then hearing/driving "your baby" running full throttle in a car...
