Author Topic: Yet another dash removal ???  (Read 989 times)
Offline HemiOrange70
« on: February 28, 2007 - 07:15:17 PM »
Yes, I have read the archived posts about dash removal. Do I just undo the bolts at the base (on the firewall-floorpan) on the steering column to drop it. I have removed the 4 (2 per side) bolts in the middle of the column and the 4 defroster vents in the dash and the 2 (one per side) bolts on each end. Is that all?I want to remove the whole dash
Offline AMXguy
Re: Yet another dash removal ???
« Reply #1 on: February 28, 2007 - 08:43:40 PM »
That's how I did it, remove the floor cover bolts and drop the column way down.  what you've said should do it other than all your wires and cables ect.
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #2 on: February 28, 2007 - 09:09:22 PM »
thanks :bigsmile:
