Is the adjuster rod for the throw out bearing longer on a bb compared to a small block?
I installed my equalizer tube, both the ball ends, and then got down to the adjustment bar for the throw out bearing and it appears to be around 1.5 inches or so too short.
My car is a 440 with a 23 spline. I believe that maybe I must have a small block thread adjuster since it is too short?
If there is a difference, who sells a good bb adjuster kit? And I need one to be as strong as original and work as good
Thanks for the help, if you can....ALAN
