Author Topic: Max lift for heads  (Read 891 times)
Offline Imlearning
Max lift for heads
« on: February 28, 2007 - 08:10:24 PM »
Its been a while since I've been on here. Too bumed out to look at my car again.
In any case. I rebuilt my motor a year ago (440). Did the standard rebuild to it... bearings, bore .030, rings, cam, etc. It never ran quite right, as on the first start up I wiped a lobe on my cam. After putting another cam in, it still never acted quite right. Always really low on power and making very odd ticking noices that I never could locate.
Then after reving it up one day in the driveway trying to hear the ticking, it killed and never started again. I checked all the usual things and nothing seemed to be wrong. But then I checked the compression, 165-170 psi on 2 cylinders, 50-60 on two others, and 0 on two more. The other two cyliders were to hard to check with my tool.
I did a compression check when first putting the motor together and all were 165-170 psi.
What could cause this compression drop?
The only thing I can think of is valve train problems. Hence why I am asking what the max lift is on a set of 906 heads. And by lift I mean the max lift before a valve stem hits the head or something. I have a Hughes cam with about .548 lift.
« Last Edit: February 28, 2007 - 11:17:38 PM by Imlearning »
Re: Max lift for heads
« Reply #1 on: March 01, 2007 - 10:14:38 AM »
anything over .520 lift should have the guide trimmed down so the retainer doesn`t hit the guide , you may also have to check the piston the valve clearance if the pistons do not have valve reliefs cut into them
Offline Imlearning
« Reply #2 on: March 01, 2007 - 03:27:12 PM »
thanks for the advise. I really hope I find something obvious when I take those heads off. I dont like hunting down mystery problems.
I do have sixpack replacement speed pro pistons, so i wouldn't think i would have my valves making out with my pistons or anything.
I'm going to have to check my receipt... but I dont recall seeing anything about the guides being cut down. We'll see what turns out in a couple of weeks when college lets out for spring break and I have time to work on it.
« Reply #3 on: March 01, 2007 - 05:14:44 PM »
The 6 pack piston has enough valve clearance to allow for .600 lift with lots of clearance so there must be other issues
Offline Dustu
« Reply #4 on: March 09, 2007 - 08:49:49 PM »
Is that the lifter ?Holy mackeral ! All that metal went through your oil system !  Rebuild time again I'm afraid ,sorry!       :stomp:
Offline GoodysGotaCuda
« Reply #5 on: March 11, 2007 - 02:02:47 PM »
..yup.  :iagree:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Imlearning
« Reply #6 on: March 16, 2007 - 10:00:49 PM »
Yep... a rebuild is on the way. I just thought it would be amusing to put that horrible lifter pic as my profile picture. As soon as school lets out this spring I'm tearing that 440 out of there and doing it all again. Oh well... should go twice as fast as now everything is clean and what not. I just hope I can find out whats wrong with it (ie... something obvious).
