Author Topic: Anyone have a drawing of a 70 440-6 fuel system with ca emissions?  (Read 1169 times)
« on: February 28, 2007 - 08:50:43 PM »
Working on my fuel system for my car. The fuel line at the filter, is it supposed to have a little tube on the side to bleed off vapor and how does it hook up? My car is a 70. It has a vent line running up to the engine compartment along with the fuel line. I am not sure of the routing with the california carbs, the number of nipples for the breather, and where it all hooks too.
The car was a 318 4 speed, I am installing the 440-6. The gas tank had a bunch of hoses run to it in the front. Do I need the vapor return ran off the fuel filter?
If I was just building it to run, I wouldnt worry with it all. But I am trying to make it look as stock for right now.
Re: Anyone have a drawing of a 70 440-6 fuel system with ca emissions?
« Reply #1 on: March 01, 2007 - 09:57:19 AM »
you need the vapor separator , it bolts on with the fuel pump it has 1 line in 3/8" off the fuel pump & 2 lines out , 1 to the carbs & one to the 1/4 " line back to the fuel tank , the other lines off the tank are just a captive vapor trap , if there is a 3rd line to the front it would connect to the fuel bowl but I think that started in 71
« Reply #2 on: March 01, 2007 - 11:35:50 AM »
Ok, that's what I was thinking. My fuel pump is 3/8ths inlet and outlet, then the fuel filter has a 1/4 inch vapor nipple out the side and a 3/8ths outlet out the top. It just seem like something sould of been in between.  I guess the crank case breather will have a line going to the center carb vent, and the air cleaner.
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
« Reply #3 on: March 01, 2007 - 09:00:34 PM »
the breather is the rare one with connections for 3-hoses.
Just finished redoing everything fuel-wise on mine .
So if you need specific pics... let me know
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
« Reply #4 on: March 01, 2007 - 09:06:47 PM »
I got a 3 nipple breather on my other car, but isn't hooked up cause I stuck it on the 74 challenger to plug the hole.
Can you give a diagram of the 70 6 pack cuda engine with the ca emission carbs? Where all the vents and lines hook up under the hood. That would be super for me if you could.
  • HvacMan
« Reply #5 on: March 01, 2007 - 09:10:08 PM »
s'pose challenger would be the same :dunno:
Eric
Bay Area California
Offline farmboy70
« Reply #6 on: March 03, 2007 - 07:21:30 PM »
This may help ,it is a CA built 70 Roadrunner with ecs.
« Reply #7 on: March 03, 2007 - 07:34:02 PM »
Yes, those pics helped a lot. I was also curious about the vaccum advance until I saw yours....thanks
