Author Topic: Door & Trunk Lock Cylinders  (Read 3157 times)
Offline 74 340 4speed
« on: March 05, 2007 - 01:46:14 PM »
I need to put a new set of door lock cylinders in my car because one of them is missing and I don't have the key to the other.  Do I have to remove the door handles to install these?  If so, what is the best way to remove the door handle?  Who sells the best quality door lock cylinders?  I am also needing to replace my trunk lock cylinder because the key was lost to it too.  I have removed the old lock cylinder and bought a new generic one from the parts store, but there is no way it would work.  The only places I have found these is year one and laysons.  Are there any other suppliers?
Andy
1967 Camaro SS: 406 sbc 505 hp/506 ft lbs|4 speed|Posi|3.73s
1969 C/10  350|Turbo 350
1969 Dodge D300 318|4 speed|Dana|4.88s
1972Nova: 350|Turbo 350
1974 'Cuda: 340|4 speed|Dana 60|4.10s|posi
1999 Camaro SS: Auto|Longtube Headers|True Duals|TT2s
2013 Challenger R/T: 6 speed|Hurst with pistol grip|mopar performance exhaust|super track pak
71challengher
Re: Door & Trunk Lock Cylinders
« Reply #1 on: March 05, 2007 - 02:02:41 PM »
Try R/T Specialties.
Offline Tropicalcats
  • Don't Ever, Ever Give Up
« Reply #2 on: March 05, 2007 - 02:20:08 PM »
SOLD
« Reply #3 on: March 05, 2007 - 02:43:28 PM »
You do have to remove your door handles. Take off the door panel. You will need a long extension on your ratchet to reach the nut that holds it in place. There is a neat hole to reach this nut too. There are 2 linkages that will have to be taken off the door handle also. If you have small hands, or long skinny fingers, you might not have much trouble. The lock cylinder is just held into the door handle by a screw, I believe.
71challengher
« Reply #4 on: March 05, 2007 - 02:45:02 PM »
Yep, you need little hands.
« Reply #5 on: March 05, 2007 - 04:16:33 PM »
Little is something I don't have.  :pullinghair: My parents were Clydesdales.   :bricks1:
« Last Edit: March 05, 2007 - 04:20:27 PM by MEK-Dangerfield »
« Reply #6 on: March 05, 2007 - 05:07:34 PM »
Yea my hands aren't that small.  I guess it's gonna be a P.I.T.A. for sure.  Is it easier to reach some of the stuff from the top of the door with the door glass down, or will all of it be accessable with the glass up?
Andy
« Reply #7 on: March 05, 2007 - 05:11:46 PM »
A locksmith can make a key for your locks or I suppose change the tumblers in a lock to fit an existing key(they can for house/business locks anyway).
« Reply #8 on: March 05, 2007 - 05:12:05 PM »
The girls must love you.
Richard
SOLD
« Reply #9 on: March 05, 2007 - 05:13:29 PM »
Richard
OMG!!
 I didn't think of it THAT way.   :smilielol:  :smilielol:  :smilielol:
« Reply #10 on: March 05, 2007 - 05:16:41 PM »
You did't mention the ignition being a problem.
You know the ignition key is what is used for the doors.
« Reply #11 on: March 05, 2007 - 05:21:50 PM »
If you take your door panel off and have a look, you will see what needs to be done. If I can do it, anyone can. You have to reach everything from behind. The door latch rod, and the rod for the door lock, reside in plastic clips that you need to slip them out of. I believe the window down let access to them best. A confession here, getting the door handle out isn't the problem. It's putting it back in.  :bricks1: That's when you need small hands, or long skinny fingers. Those rods are a little tough to get back in to their clips.  :pullinghair: A long flat blade screwdriver helped me in the past.
71challengher
« Reply #12 on: March 05, 2007 - 05:48:20 PM »
Right, and you did that all by yourself :poopoke: :stirpot:Who has little hands? :clueless:
« Reply #13 on: March 05, 2007 - 05:58:34 PM »
Yea, I know.  :thumbsup:  I replaced the ignition lock cylinder when I was tracking down my ignition troubles.  Plus, my old ignition lock cylinder was hard to get the key in and out of.  I may end up buying the set from so that I have one key for the ignition and doors.  The passenger door lock cylinder works fine with the old key that I have.  When I first started working on the car, the driver's side door panel was taken off and kept, but the door handle, lock cylinder and dock lock knob were lost.  :crying:
Andy
« Reply #14 on: March 05, 2007 - 06:14:08 PM »
an eBag with the whole tamale for $70   The door locks don't seem right to me but they may use a stock photo.
http://cgi.ebay.com/ebaymotors/LOCK-SET-CHALLENGER-GTX-CHARGER-MOPAR-73-74-75-85_W0QQcmdZViewItemQQcategoryZ140706QQihZ005QQitemZ150093996369
