Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
x heads vs. j heads ?
« previous
next »
Print
Pages: [
1
Author
Topic: x heads vs. j heads ? (Read 2975 times)
72cudaguy
Jr. Member
on:
March 06, 2007 - 05:38:51 AM »
Hello everybody, I have a 72 cuda with a numbers matching 340. I'm just getting started with the motor tear down and rebuild. I'm looking to rebuild fairly hi po, is there that much of a difference in the x heads to warrent trying to track a pair down or should I just stick with the stock j heads ? thanks for any input
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: x heads vs. j heads ?
Reply #1 on:
March 06, 2007 - 09:32:21 AM »
There is virtually no difference between the X or J heads but if you 40 more HP use the later 308 swirl castings I generally port these heads to get closer to 60 hp gain
Last Edit: March 08, 2007 - 09:29:52 AM by Chryco Psycho
Logged
HP2
Resident
Reply #2 on:
March 08, 2007 - 07:20:13 AM »
In stock form, the 308s flow better than X or J heads.
Logged
mrbill426
Full Member
Reply #3 on:
March 08, 2007 - 09:07:32 AM »
I've got stock J heads on my '72 too, they have small valves. Wonder what it would cost to install larger ones? I hear Mopar now sells bare castings for the 340 with larger openings.
Logged
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
March 08, 2007 - 09:31:16 AM »
I would hit the wreckers & get 308 castings for $100 or less of a truck instead of putting $$ into X or J castings
Logged
mrbill426
Full Member
Reply #5 on:
March 08, 2007 - 01:18:12 PM »
Okay, so the 308 heads are truck heads that have the larger valves? Are they open chamberd?
Logged
MOPAR or NO car!
dimples
Jr. Member
(dodgetkboy78)
Reply #6 on:
March 08, 2007 - 04:46:17 PM »
They have the standard 1.88/1.60 valves, and are open chamber. The main difference is intake port design, and higher % flow of the exhaust.
Logged
HP2
Resident
Reply #7 on:
March 08, 2007 - 07:27:26 PM »
...or since you are going through a rebuild anyway, just put on magnum heads, intake, rockers, and pushrods in it. Then you get high swirl, fast burn, high flow, and small chambers all in one.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #8 on:
March 08, 2007 - 07:42:23 PM »
& the awesome chevy ball stud rocker system
Logged
dimples
Jr. Member
(dodgetkboy78)
Reply #9 on:
March 09, 2007 - 10:53:41 AM »
Well, it's a bit tougher than the chev............they go over 200,000 miles in a stock engine.
But real engines have rocker shafts.
Logged
Dustu
Jr. Member
Reply #10 on:
March 09, 2007 - 08:43:58 PM »
308's must be a good increase ,I have a set that was on a Super Stock Cuda 340,how did he manage that ?Legal ?
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
