Author Topic: Alternator wiring????  (Read 1020 times)
Offline 74 340 4speed
« on: March 06, 2007 - 05:45:31 AM »
If anyone has pictures of the wiring on the alternator for a 73-74 'Cuda or Barracuda, I would really appreciate it.  I have read the wiring diagram and hooked it up to the best of my knowlege, but it isn't charging accordign the gauge in the car.  I have the black wire attached to the stud on the back of the alternator, then I have the green wire attached to the middle terminal.  There is one remaining terminal, but I have nothing hooked to it.  From what I could tell from the wiring diagram, a wire ran from this terminal to a part of the choke assembly for the carb.  Since I no longer have the factory carb(dual line 750 holley manual choke), what do I need to do about this wire?  My car has the stock electronic ignition system on it if that makes any difference.  I was going by this diagram. http://www.tunerz.com/downloads/74BarracudaWiring.zip
Andy
1967 Camaro SS: 406 sbc 505 hp/506 ft lbs|4 speed|Posi|3.73s
1969 C/10  350|Turbo 350
1969 Dodge D300 318|4 speed|Dana|4.88s
1972Nova: 350|Turbo 350
1974 'Cuda: 340|4 speed|Dana 60|4.10s|posi
1999 Camaro SS: Auto|Longtube Headers|True Duals|TT2s
2013 Challenger R/T: 6 speed|Hurst with pistol grip|mopar performance exhaust|super track pak
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
Re: Alternator wiring????
« Reply #1 on: March 06, 2007 - 06:22:52 AM »
check the diagram  for other wire
« Reply #2 on: March 06, 2007 - 06:32:48 AM »
There was a fast idle solenoid that piggybacked off one of the wires, blue I think.
« Last Edit: March 06, 2007 - 06:34:22 AM by bullitt99 »
