Author Topic: Fuel Guage Works  (Read 1240 times)
nivvy
Fuel Guage Works
« on: March 06, 2007 - 06:26:38 PM »
Well I finally figured out the problem!!!  :horse:  :horse: I just got in me new fuel sending unit... and after several ohm tests it was pointing to the sending unit...however after I removed the current sending unit I discovered that the float was bent enough that the float wouldnt pass by the pick up tube... thats why the gas guage was rising to E and not going past there!  So I bent it clear and wired everything back up and the guage went to almost 1/4 tank which is good because I put 5 gallons of gas in the car....so tomorrow I will put another 5 gallons in and it should go up to about half.....how many gallons is a challenger gas tank ??? 20
StROkEr
Also I have a brand new sending unit for sale that I never used,...
Offline pink panther
Re: Fuel Guage Works
« Reply #1 on: March 06, 2007 - 06:33:46 PM »
I think about 15 gallon is what mine holds
nivvy
« Reply #2 on: March 06, 2007 - 06:40:49 PM »
looked up the specs on mine and it is 18 gallons...
« Last Edit: March 06, 2007 - 06:51:47 PM by StrOkEr »
Offline GoodysGotaCuda
« Reply #3 on: March 06, 2007 - 07:04:25 PM »
Spec should be 18.
I remember mentioning to someone to check the float.  :bigsmile:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #4 on: March 07, 2007 - 08:19:50 AM »
 :thumbsup:  Glad to see the mystery is getting solved!
Great work, StrOkEr!
Offline DAYLEY/CHALLENGER
« Reply #5 on: March 07, 2007 - 08:46:56 AM »
See, its usually the simple things...I have the same kind of luck but  I haven't found the simple thing yet with my problem.
Dave or David
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #6 on: March 07, 2007 - 11:16:41 AM »
Good luck on the next 5 gallons  :2thumbs:
nivvy
« Reply #7 on: March 07, 2007 - 12:56:57 PM »
well I added another 5 gallons to the car and the needle went up past 1/2 tank a little so I guess is all good now!!!!  :burnout:
I was almost checking into a clinic over this ...  :pullinghair:
« Last Edit: March 07, 2007 - 12:58:54 PM by StrOkEr »
« Reply #8 on: March 07, 2007 - 02:53:46 PM »
   :smilielol:
I understand how you feel.  :grinyes: For the record, Your car has a 18 gallon tank.
