Author Topic: Dome light Trouble.  (Read 879 times)
Offline CudaDownUnder
Dome light Trouble.
« on: March 07, 2007 - 06:06:27 AM »
Hi Folks,
The dome light in my '73 Cuda isn't working so I decided to pull out the globe and take a look. The globe is a single contact type and is faulty. I got a new globe and went to install it but then noticed that the dome socket has two contacts. So, I have the wrong globe. I believe that the correct one is a 1004 Double Contact - not sure of the watts though.
Since I didn't have a globe I decided to use my multimeter and see what the two contacts were all about.
To my surprise each contact has +12VDC on it - all the time - that is with the doors open or closed and with the instrument light going on when opening the doors and turning off after the delay timer switches off.
Why would I have +12VDC on the Pink and Yellow wires going to dome light all the time? ???
Thanks in advance, Ed.
1973 Plymouth 'Cuda
Re: Dome light Trouble.
« Reply #1 on: March 07, 2007 - 06:10:48 AM »
Yes, +voltage present all the time the ground is interupted when the doors are closed.
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
« Reply #2 on: March 07, 2007 - 06:43:22 AM »
PINK IS +12 VOLTS
YELLOW IS GROUND SWITCHED
Do you have a key in the buzzer option??? if so then 12 volts is back feeding thru the buzzer!
« Reply #3 on: March 08, 2007 - 01:11:29 AM »
Thanks guys.
I got the correct globe and it is working as it should.
I think I got confused because I kept thinking that the body of the globe went to GROUND - it's obvious now that it doesn't!
71 DEPUTY - I don't think I have the key-in buzzer. The only buzzer I've found so far is for the seat belts.
Thanks again and stayed tuned for more questions - in another hour it will be me verses the heater/demister/air con... :roflsmiley:
1973 Plymouth 'Cuda
Offline 71 DEPUTY
    • Cardomain
« Reply #4 on: March 08, 2007 - 07:06:09 AM »
check your ing. switch wiring harness by the connectors below the dash- two small red wires are for the key in the buzzer!  buzzer may not be installed but wiring is usually there!!!
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
« Reply #5 on: March 08, 2007 - 08:32:50 PM »
was that buzzer standard on all '70's or an option? just curious...mine works.
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
