Author Topic: What size rear-end?  (Read 2115 times)
Offline 67vertman
  • Member since 9-23-2005
What size rear-end?
« on: March 08, 2007 - 10:06:34 PM »
Can you tell if this is a 7.25 or 8 3/4?
Re: What size rear-end?
« Reply #1 on: March 08, 2007 - 11:50:18 PM »
8 3/4 ..........it is the only diff without a removable back cover
Offline jvike
  • Pro-Touring Cuda
« Reply #2 on: March 09, 2007 - 07:50:37 AM »
Also called "Banjo" axle.
Offline moper
« Reply #3 on: March 09, 2007 - 10:34:12 AM »
If the tag's correct, it's a Sure Grip 8 3/4 that someone stole the snubber off...lol.
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #4 on: March 09, 2007 - 01:01:28 PM »
Sorry, not to take over this thread but do the Sure Grips have a tag on the outside somewhere to indicate it's a Sure Grip?
I know that GMs had a tag that said something like "limited slip differential fluid only".
Thanks!
Offline 67vertman
« Reply #5 on: March 09, 2007 - 04:20:38 PM »
Thanks guys! your knowledge is in valuable.   :2thumbs:
The seller said it was a Sure Grip with 3:23 gears.  :clapping:
I just wanted to make sure he was telling the truth.
« Reply #6 on: March 09, 2007 - 04:30:21 PM »
I'll be honest, I could only tell it was an 8 3/4 by the shock mount plates. Do you know how to prove it's a 3:23 sure-grip ?
Offline 67vertman
« Reply #7 on: March 09, 2007 - 06:44:09 PM »
Quote from: MEK-Dangerfield link=topic= :poopoke:31211.msg312782#msg312782 date=1173475821
What? you want proof?  :smilielol:  :stirpot:  :poopoke:
You don't take the owners word for it?  me either.  :roflsmiley:
so...I asked on another thread   http://www.stockmopar.com/_images/brochures/1970-dodge-challenger-dealer-brochure/original/1970-dodge-challenger-dealer-brochure-14.jpg and it looks like three speed cars only came with 3:23 gear ratios in either open or Sure Grip.
But, as always I could be wrong.
Alaskan_TA
« Reply #8 on: March 09, 2007 - 09:49:53 PM »
Thanks!
From 1969 and back, sure grip rears had the tag.
No tag from 1970 and up.
Barry
« Reply #9 on: March 10, 2007 - 07:12:09 AM »
...and after 30 years I don't know that I would trust that any tags that are installed, or even missing for that matter, are accurate.
Definetly worth checking out if it's presence is a key factor in the price negotiation. Looking at the pic, it doesn't seem to have an engine or trans in it either so I wonder of they are keying in on this as a selling point. A replacement 3:23 Sure grip can be found at salvage yards for around $100 and online for up to a grand. Keep that in mind of the seller is wanting a higher price because of the presence of a 3:23 Sure Grip that may be able to be replaced for less than the value it adds to the negotiated price of the vehicle.
« Reply #10 on: March 10, 2007 - 11:41:33 AM »
Thanks for the info!  :thumbsup:
Offline moper
« Reply #11 on: March 13, 2007 - 10:11:52 AM »
I wasnt sure when the tags stopped. You cant tell the ratio, just that it says "Use sure grip fluid only" or something on the tags. i have one at home on the wall...lol. It's painted orange looks like, and all the ones I saw are bare aluminum. Which is why I say "if they are telling the truth..."
Offline 73EStroker
« Reply #12 on: March 13, 2007 - 09:46:18 PM »
Jack er up - mark the tire at the top = SG should make both wheels turn even - count the number of times the pinion goes round. There is your gear ratio. If one wheel spins backward and one forward then you have an open diff.
Barry (Salmon Arm)
