Author Topic: B&M MEGA SHIFTER???  (Read 1519 times)
Offline Carlwalski
B&M MEGA SHIFTER???
« on: October 07, 2003 - 12:01:56 PM »
Wanting your peoples views and thoughts on the B&M Mega Shifter, Do you have one, used one or know someone with it? If so whats it like? Cheers.  :)
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline 1973challenger360
Re:B&M MEGA SHIFTER???
« Reply #1 on: October 07, 2003 - 02:33:11 PM »
There great with reverse manual valve bodys,  For standard I prefer a slapstick ! Ma Mopar made them right...
Offline Carlwalski
« Reply #2 on: October 07, 2003 - 02:45:44 PM »
Yeah I will be going Reverse manual valve body it feels better slamimng down for up than pushing forward. Yeah slap-stick would be good to.  8) What do you have to say about the Hurst V Matic 2 Shifter?? Cheers ;)
Also......If I want to have it set up so I can shift down to up shift my gears does that mean I will need a Reverse manual body, and that I will have to shift gears manually all the time? Is there any way I can shift down for up shifts and still keep normal Auto mode? Cheers I need some hlep on this one guys  ??? :)
« Last Edit: October 07, 2003 - 06:33:55 PM by NZ 440RT »
Offline Carlwalski
« Reply #3 on: October 13, 2003 - 08:27:51 AM »
Don't worry I have it sorted now, I am going to have a slap-stick for a while then maybe later get the B&M Megashifter forward pattern not reverse because you lose the normal auto fuction and that would suck for cruising and stuff.  ;)
