Author Topic: Carb and Intake Recommendation Needed  (Read 729 times)
Offline loco340cuda
« on: March 12, 2007 - 08:37:58 PM »
I'm currently having my 416 stroker built and I need to settle upon what intake and carb I'm going use.
Here is my setup:
340 stroked to 416
Stock 1969 'x' heads
Mopar 484 purple cam
headers with 3" exhaust
70 Cuda w/4 speed
3.23 gears (going to 3.91 sometime this year)
27" tires
The car will mainly be street driven with maybe a couple of trips to the track a year.
I'm thinking of using the Edlebrock RPM air gap intake with an Eddy 800cfm AVS thunder carb. I'm also considering a Holley DP750.
I would like to hear what carb and intake you guys think would work good with my setup.
-Thanks
1970 Cuda 340 4-speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Re: Carb and Intake Recommendation Needed
« Reply #1 on: March 13, 2007 - 12:13:43 AM »
if you have the height for the RPM air gap that is what I would use
 Personally I would use the Holley Street HP 750 carb  [#80751 I think] it is very adjustable & Has out performed the similar but older 4779 holley Dp 750
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #2 on: March 13, 2007 - 12:57:35 AM »
I don't mess with holleys much, so I don't know.
Offline dimples
  • (dodgetkboy78)
    • American car and truck forums
« Reply #3 on: March 13, 2007 - 01:04:09 AM »
Good manifold choice, as far as the carb, either one will work fine, I think the Holley will have a slight performance edge, but may be more finicky than the AVS
Offline moper
« Reply #4 on: March 14, 2007 - 06:59:39 AM »
With the stock heads, I dont think it really matters too much. All will perform about the same. The Air Gap, a std RPM if the hood gets in the way, and I'd run the 800 Thunder too.
Offline loco340cuda
« Reply #5 on: March 14, 2007 - 01:14:44 PM »
Guy's, thanks for all the feedback.    :cheers:
