Mr.Mopar,
You will be happier after the switch. You can also change it back after you find another car later. One more thing, when you have your u-joints assembled, make sure that the joint is compressing the area that contains the grease-zerk opening and not trying to pull it apart. The front and rear. If you do that, they will never fail.
