Author Topic: restoring Challey Rallye dash with RTE bezels  (Read 1072 times)
Offline hemi68charger
  • Charger Power!!
    • Houston Mopar Club Connection
« on: March 14, 2007 - 05:04:41 AM »
Hey gang..
Has anyone restored their Challenger Rallye dash cluster using the new RTE woodgrain bezel? I just recieved it today and it's awesome. The only drawback that makes me anxious is the curve forming of the bezel since it comes deliveried flat. Any experience would be appreciated.... It comes with instructions which I understand, but nothing's better than experience...
Thanks..
Troy
'69 Daytona 426 HEMI-727
'70 Superbird 440 - 4speed
Re: restoring Challey Rallye dash with RTE bezels
« Reply #1 on: March 14, 2007 - 06:06:32 AM »
It's not difficult at all. Just use a little glue, and clamp it down overnight so it stays molded in the bend real good.
  • Charger Power!!
« Reply #2 on: March 14, 2007 - 07:10:08 AM »
It's the actual "bending" it that makes me anxious..... lol Once bent, it's there..... I was thinking of using a wooden dowel or something that'll give uniform pressure all the way across the face. Obviously, I'd use something like a cloth between the bezel and tool....
Troy
« Reply #3 on: March 14, 2007 - 09:33:38 AM »
Start on the right edge, and work your way towards the bend. It will be easier that way. Don't forget to fold those little tabs over too.
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #4 on: March 14, 2007 - 10:03:42 AM »
 :iagree: I just did one a couple of days ago and that is exactly how I did it. came out fine.
1996 Dodge Viper GTS Coupe
Offline Lunchbox
« Reply #5 on: March 15, 2007 - 10:21:29 AM »
Youll have to take the backing plate off your old ones or by the repo ones tha PG Classics sell.
Lunch
  • Charger Power!!
« Reply #6 on: March 19, 2007 - 12:24:35 PM »
The part that gets me is the instructions say not clueing the new bezel to the backing plate first, then install....... They want the backing plate on first, then push down the bezel.......... Guess I'm worrying too much........
Troy
Offline JayBee
« Reply #7 on: March 19, 2007 - 05:27:32 PM »
I didn't glue the bezel to the backing plate until I made the curve and was satisfied with the fit. Also, I used my original as a guide for the bend and improved it a bit with a wooden dowel. Then I put the backing plate onto the plastic housing first and glued the bezel that way. Even bought a 6" C-clamp to go over the left 90 degree side so I could put pressure right in the corner. I was really paranoid about getting it right, so don't feel bad. If you do a thread search you'll find more info, this has come up before....Good Luck
John
1970 Barracuda convertible
2014 Toyota Avalon
