Author Topic: 1050 Dominator Flow  (Read 753 times)
nivvy
1050 Dominator Flow
« on: March 14, 2007 - 05:43:39 PM »
Got my new 1050 Dominator today from BIGS Performance...My question is the spec card say Primary Jet 90 and Secondary Jet 90 .... so what is my actual cfm now??? I thought stock dominators come with 88 jets ...
Re: 1050 Dominator Flow
« Reply #1 on: March 15, 2007 - 01:16:09 AM »
2 jet sizes is not a big deal this could be from a number of reasons , larger air bleeds can soften the pull at the jets allowing for larger jetting to compensate , or the booster design could be less efficient , or the air flow could be higher all would need larger jetting
Offline moper
« Reply #2 on: March 15, 2007 - 07:19:46 AM »
Jetting has nothing to do with cfm ratings. Bigs just installed jets that "should" be right for your car. All carbs should be expected to require some adjustments.
