Author Topic: 440 intake  (Read 1423 times)
Offline Stacked440
440 intake
« on: March 14, 2007 - 06:51:11 PM »
I have a TM7 that came on my 440 when I bought the car 2 years ago...however I just received information that the TM7 is really only effective on the strip, not really designed for street/cruiser.  There was another thread that suggested a Holley Street Dominator intake.  Would that work well for my motor? It has a 670cfm holley street avenger on it and a stock cam.  Lemme know, now is the time I can change with relative ease! :working:
-Kyle-
Offline GreenFish
Re: 440 intake
« Reply #1 on: March 14, 2007 - 07:25:39 PM »
you really cant go wrong with the eddy performer RPM. The street dominator is very similar. Either one would work
Offline Stacked440
Re: 440 intake
« Reply #2 on: March 14, 2007 - 10:31:18 PM »
The only one summit lists for a 440 holley street dominator has an EGR, I don't want an EGR.  do they make them without them that I'm just not seeing?  Or is there someway that having the EGR doesn't matter or what? :dunno:
-Kyle-
Re: 440 intake
« Reply #3 on: March 15, 2007 - 01:22:53 AM »
all Street Dom intakes have EGR provision , I have never used the EGR ports , they are easily blocked with no bad effect ,, the Street dom is a great intake part # 300-14 for 440
 my questionis the 670 CM carb , far too small for a 440 unless you are under 4000 rpm all the time
Offline Stacked440
Re: 440 intake
« Reply #4 on: March 16, 2007 - 02:59:03 PM »
Didn't 440's come from the factory with 650 carters on them?
-Kyle-
Re: 440 intake
« Reply #5 on: March 16, 2007 - 08:18:35 PM »
Probably but the 440 also came with 3- 2bbls & close to 1000 CFM & they run better that way
Offline Stacked440
Re: 440 intake
« Reply #6 on: March 16, 2007 - 10:54:18 PM »
What do I have to do to block off the EGR on the street dominator?
-Kyle-
Re: 440 intake
« Reply #7 on: March 17, 2007 - 12:37:06 AM »
thread in the pipe plugs included with the intake
Offline MG440RT
Re: 440 intake
« Reply #8 on: March 19, 2007 - 02:04:50 PM »
Center carb is 350 cfm and the outboards are 500 cfm's each...= 1350 cfm
Thats why we get the trademark ' bog ' when we open those outboards...
But THEN...
Re: 440 intake
« Reply #9 on: March 19, 2007 - 04:19:34 PM »
well that is sort of correct Except that 2 bbls carbs are flow rated at 3" of vacuum & 4 bbls are rated at 1.5" of vacuum so the actual flow cannot be directly compared & if they are tuned correctly there is no bog just tire smoke  :burnout:
Offline MG440RT
Re: 440 intake
« Reply #10 on: March 20, 2007 - 09:48:56 AM »
I stand corrected...sort of .
Re: 440 intake
« Reply #11 on: March 20, 2007 - 09:53:55 PM »
I just completly rebuilt my 6 pack carbs, and so far I have no bogs at all and the throttle response is right there when I need it :clueless: I built them back stock specs and must of did them right.
I am either lucky, or I have built a few holleys and 6pks before :roflsmiley:
But seriously, when set up right, they work like they were intended to. Take no short cuts and know how to tune an engine, not just carbs :2thumbs:
