Author Topic: Misc Engine Parts  (Read 770 times)
Offline asm74
Misc Engine Parts
« on: March 17, 2007 - 05:10:24 PM »
Miscellaneous parts available, make offers.   :ylsuper:
Prefer pickup in Oakland CA, but will ship smaller items at buyers expense
1995 5.2L FI Magnum Engine Parts:
    Timing cover
    Water Pump With Fan adapter
    Underdrive Pulley set (Crank and Alt)
    Alternator
    Alternator bracket
    Intake Manifold (Barrell Style) with Fuel Rails and injectors
    Throttle Body
    Rear Sump Oil pan, for trucks
*SOLD* 1995 A518 4 Spd auto transmission and torque converter from 1995 Dakota !Clean!
    (I would use it myself but I cant afford the expense of the modifications right now)
1973 318 LA Engine Parts
    Bare Block, bone stock, needs cleaning
    Connecting Rods
    Flat Top Pistons
    Stock Heads (Still assembled)
    Stock Push Rods, Lifters, Cam Shaft (probably good for an art project lol)
    Stock Crank Shaft
    Stock Air Cleaner Assembly
    Stock Starter
1973 Dodge Challenger Parts
  *SOLD*  Near Complete Front Disc Brakes: Calipers, Spindles, Cylinder, Booster, Rotors, Prop Valve TOTALLY USEABLE!
    Torque Converter
Other Parts
    Practically New Mopar Performance center sump LA Oil Pan (Doesn't fit magnum block  :-[)
    Rebuildable Holley 4bbl Carb, Vacuum Secondaries, Manual Choke
    Early 360 Snorkel Air Cleaner Assembly for 2bbl Carb
    Lakewood Universal Traction Bars, Still in box, opened for inspection
PM me for a fast response!
« Last Edit: March 23, 2007 - 09:08:22 PM by asm74 »
73 Challenger
Offline 71bigblock
    • Steve's Mopars
Re: Misc Engine Parts
« Reply #1 on: March 17, 2007 - 09:11:35 PM »
How much for the 518/torque converter?  Miles?  You can PM me if you wish.  Could you ship it?, Im guessing not   :walkaway:
Offline CrazyPete
« Reply #2 on: March 17, 2007 - 11:16:17 PM »
how much for all the brake parts?
1970 Dodge Challenger T/A      http://heartlandmopars.com
1970 Plymouth Barracuda Gran Coupe
1976 Dodge Dart Sport
"Is that an oil leak?  No it's just sweat from all that HORSEPOWER"
Offline asm74
« Reply #3 on: March 20, 2007 - 04:25:16 PM »
Sorry For the late reply guys.  PM me for a faster response.
71bigblock:  I'm really not up to shipping this transmission. It's big.  It's heavy. Really freakin heavy. Where are you located, I'll try to see if I can get a quote.  As for the price, PM me.  I have an offer locally.
CrazyPete: A local guy is going to come by and check out the brake system tonight.  Ill PM you if he doesn't take it.
Thanks!
73 Challenger
