Still a little hard to see but I wanted you to see the key-in ignition-light, the emergency flasher switch and push-to-turn-to-lock key release lever.
I noticed that they are still hard to see. This is the stuff you get when you put a mopar column in a Mopar, that all still works when you plug it in. Remember, the Ignition harness AND turn signal harness plugged right in too!
Ask Flaming River if theirs has all that too. I don't know if theirs does.
