Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Pushrod Wear ???
« previous
next »
Print
Pages: [
1
Author
Topic: Pushrod Wear ??? (Read 737 times)
nivvy
Guest
Pushrod Wear ???
on:
March 18, 2007 - 09:04:25 PM »
can anyone explain why the marks are on my pushrods that I removed
The worst one on the right has a slight groove gut into it
were they hitting the head
I was using 1.6 rockers but have since changed to 1.7 Full roller rockers and shorter pushrods ....
Last Edit: March 18, 2007 - 09:09:39 PM by StrOkEr
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Pushrod Wear ???
Reply #1 on:
March 18, 2007 - 09:13:33 PM »
there are 2 ways to correct this , 1 when I port heads I always grind extra clearance beside the port for pushrod clearance , second you can use shims to move the rocker over slightly to keep the pushrods from rubbing the head
Logged
nivvy
Guest
Reply #2 on:
March 18, 2007 - 09:28:12 PM »
Thx Chyrco....since I have a bunch of shims I think I'll go that route ...
I wonder if this is what was causing the mysterious tapping noise I was hearing in the motor
Last Edit: March 18, 2007 - 09:29:55 PM by StrOkEr
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
March 18, 2007 - 09:47:51 PM »
could well be it will transfer sound to the engine
Logged
moper
Resident
Reply #4 on:
March 22, 2007 - 09:53:20 AM »
You can also verify the geometry is right. It's much more critical on the higher than stock ratio rockers. I have the pushrod holes enlarged too..lol.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Pushrod Wear ???
