Author Topic: Carb Ratio  (Read 615 times)
nivvy
Carb Ratio
« on: March 19, 2007 - 05:00:44 PM »
Got my new 1050 Dominator carb from BIGS and it has an external linkage system on it to change ratios... 1.1 - 2.1 - 3.1 - & 4.1 ....what is the purpose of this ???  :burnout:
Re: Carb Ratio
« Reply #1 on: March 19, 2007 - 09:43:18 PM »
on  a tunnel ram you can open the secondaries at the same time & ratio as the primaries , for street use it is more typical to open the primaries 35% or so before starting to open the secondaries
nivvy
Re: Carb Ratio
« Reply #2 on: March 20, 2007 - 09:22:57 AM »
So If I have the setup on 1:1 it will open the secondaries faster as opposed to having it on 4:1 ???
Re: Carb Ratio
« Reply #3 on: March 20, 2007 - 09:38:11 AM »
yes , the secondaries will open at the same rate & time as the primaries with 1:1
Offline PlumCraZRT
Re: Carb Ratio
« Reply #4 on: March 22, 2007 - 01:19:23 AM »
Why didn't you call Big's?  You gave us their number!  :roflsmiley: :smilielol:
mmmmm.... Mopar.... *drool*
