Author Topic: Alternator Wiring  (Read 621 times)
nivvy
Alternator Wiring
« on: March 19, 2007 - 08:16:32 PM »
I have a 3 wire setup so my question is....I looked at the factory wiring diagram and it's obvious what the battery wire goes to... but there is a green and blue wire ??? the battery is the whole way at the bottom of the alternator then a middle connection and a connection at the top of the alternator...so which one does the blue/green go to ??? thx
 :burnout:
Re: Alternator Wiring
« Reply #1 on: March 19, 2007 - 09:14:16 PM »
here's a pic from my '73
nivvy
« Reply #2 on: March 19, 2007 - 09:31:37 PM »
I have an aftermarket powermaster..setup is a little different...wonder if the green wire still goes in the middle ???
« Reply #3 on: March 19, 2007 - 09:45:18 PM »
it makes no difference hook them up to the 2 terminals either way
Offline oldkimmer
« Reply #4 on: March 20, 2007 - 06:17:22 AM »
The factory way is whichever wire has power in the key on , engine off mode (with wires off the alt) goes to the top, but like cp says  it realy doesnt matter...........kim....
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
