Author Topic: Paint guns, which one do you prefer?  (Read 1123 times)
« on: March 19, 2007 - 11:15:29 PM »
There are so many out there. What's a good deal and paints well yet doesn't cost 4-500? Those 20 dollar units,... has anybody ever had luck using them before? Or save them to just prime with?
Offline Stacked440
Re: Paint guns, which one do you prefer?
« Reply #1 on: March 19, 2007 - 11:26:06 PM »
i wouldn't shoot anything but primer with a 20 dollar gun.  I use Devilbiss, they are a higher end paint gun but they do have some cheaper models that are more affordable and still do a pretty nice job.
-Kyle-
Offline ksierens
    • 70 Challenger Resurrection
« Reply #2 on: March 20, 2007 - 04:00:01 AM »
I just bought the DeVilbiss StartingLine gun set from my local painters supply for about $135.  I comes with a standard HVLP and a touchup HVLP gun, and two tips for the standard gun, one for high solids primer, and a finish tip.  I also comes with a regulator and cleaning tools. I love it, especially when you use the ziplock liners, which allow you to turn the gun upside down. I have used cup guns and pressure pots, but this seems to use a lot less paint, and there is hardly no over spray.
Here is a link the it on the Eastwood site.
http://www.eastwoodco.com/shopping/product/detailmain.jsp?itemID=15987&itemType=PRODUCT&iMainCat=1339&iSubCat=1354&iProductID=15987
Kurt - SE Michigan
Offline 70challengerrt
« Reply #3 on: March 20, 2007 - 04:07:46 AM »
For paint and clear only DeVilbiss. For primer I have a cheaper gun.
« Reply #4 on: March 20, 2007 - 06:31:59 AM »
Check these folks for supplies & equipment http://www.smartshoppersinc.com/index.html
They carry Devilbis from low to high end and have great deals on supplies.
« Reply #5 on: March 20, 2007 - 07:31:11 AM »
I was on the Smartshoppers looking at the guns. Why do you need extra tips? and what are the different sizes for and do? Do they change the pattern?
This was a gravity feed primer gun.
Includes: 1.8mm, 32 oz. aluminum cup w/push on lid. Filter, spray gun lube. Built on the same platform as the GTI series guns.
*Extra Tips in GTI - 1.2, 1.3, 1.4, 1.5, 1.6, 1.8, 2.0, & 2.2mm are available for $41.50 each
 $209.50 ea.
Offline ksierens
« Reply #6 on: March 20, 2007 - 07:37:51 AM »
The different tips are needed for the different types of paint that you will be using.  High solids primer will need a tip with a bigger hole, since it is much thicker and can be built up more than a topcoat paint would need.
Kurt - SE Michigan
« Reply #7 on: March 20, 2007 - 07:39:13 AM »
Thanks   :thumbsup:
Offline farmboy70
« Reply #8 on: March 20, 2007 - 08:09:57 PM »
Also the smaller tips will atomize the clear better for a smoother finish with high solids clears.
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #9 on: March 20, 2007 - 10:40:32 PM »
They are not cheap but I am using two SATA's, one for color and one for clear. Awesome guns.
1996 Dodge Viper GTS Coupe
« Reply #10 on: March 20, 2007 - 10:48:30 PM »
This is good stuff to learn. Thanks everyone.  :2thumbs:
