PlumcraZRT - this is the list of what I am building.
400 low deck 230 casting block bored to 4.380", 68 440 4spd steel crank, Eagle H Beam 6.76" rods, Ross stroker pistons with dish machined for 10.25 CR, ARP main studs, floating .990 pins, Lunati 0.586 solid cam 110 deg CL 256@50 duration, Aussie roller chain and gears, 0 deckd block, Cometic 040 gaskets, Indy EZ heads, Crane adjustable rockers, Holley Street Dominator manifold, Proform 950 carb, full length headers, SFI flywheel, Fluid damper. The other stuff is comestic. Anyway all of the machining and the motor complete fan to clutch will be in the neighbourhood of $13K CDN. This motor is designed for the odd rip up the strip even though the car will be set up for road type racing. It should still hold it's own on the 1320. A833OD and Dana Ford truck rear 3.73 SG converted to a Challenger setup. As CP said we should be able to post some DYNO results mid to late May. This setup gives a 451 + 040 overbore whatever that comes to total. We are aiming for 7000RPM capability when it is needed. Power band with the cam should be 2200 - 6500.
I believe you would do well with a simi,lar setup as there is a 68 Dart drag car around in BC that does high 10s with a carburetted 451 in it. That is 140MPH approx through the traps.
Good Luck with your build wherever you go with it.
