Author Topic: .120" thick intake gaskets for stock heads  (Read 697 times)
Offline drag-n-cuda
« on: March 23, 2007 - 09:52:44 AM »
Guys,
Do any of you know if someone makes a .120" thick intake gasket? When assembling my engine, I had poor port alignment. Since my heads were completely assembled and freshly bolted to my block, I ended up cutting the intake to get it aligned. The heads are now back off for oil (valve seal issues) and I plan on cutting the heads, so I don't have to cut future intakes. If I try to bolt up my cut intake after I cut the heads, I'm going to have to double gaskets or find the gasket I'm asking about. Anyone have any experience with this issue?
Thanks,
drag-n
Re: .120" thick intake gaskets for stock heads
« Reply #1 on: March 23, 2007 - 09:54:49 AM »
Welcome
you could get a mfg shop to water jet out an alum spacer , it would be easy to copy an intake gasket
Offline PlumCraZRT
« Reply #2 on: March 23, 2007 - 12:07:59 PM »
Good thinking Chryco, even if they had to CNC mill it, those guys can set it up so fast it wouldnt take hardly any time.
mmmmm.... Mopar.... *drool*
