Replacing rear springs this weekend....
Author Topic: Replacing rear springs this weekend....  (Read 1930 times)
Offline Challenger73318
« on: March 23, 2007 - 06:02:28 PM »
Any tips, advice, other assorted points of interest?
Offline 71340RT
Re: Replacing rear springs this weekend....
« Reply #1 on: March 23, 2007 - 11:15:50 PM »
Here is my old post from when I changed out my Challenger RT springs. The pictures are gone but this should give you the information needed to change the leaf springs out.
http://www.cuda-challenger.com/cc/index.php?topic=15932.msg162412#msg162412
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
« Reply #2 on: March 24, 2007 - 04:01:16 AM »
Awesome description!  Thanks!
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
« Reply #3 on: March 24, 2007 - 05:21:48 PM »
I wish I saw that post before doing my springs.  I am happy I won't have to do that job again for quite some time!
« Reply #4 on: March 24, 2007 - 06:00:10 PM »
Everything was going swimmingly according to 71340RT's post, until I got to the U-Bolts.  Seems they're stubborn.  I'm going to be cutting them tomorrow.
Offline 1BADFISH™
« Reply #5 on: March 24, 2007 - 06:36:35 PM »
Hmmmm, I really don't see you doing anything April.  :clueless:   :roflsmiley:
Charlottetown, PE
2014 GMC Sierra Crew Cab White Diamond edition.
1970 Dodge Challenger 340-6 4spd.
*Member Since* Oct 11, 2005
Offline djdmotorsports
« Reply #6 on: March 24, 2007 - 08:34:08 PM »
If rust buildup is giving you a problem heat the nuts with an oxy acetelene torch until they are nice and red, then drench them in the coldest water you have, heat them back up and as soon as they are hot they should turn right off with a socket. I deal with the rust alllllll the time at work... Damn NY and its salt.
1966 Plymouth Valiant V200
1973 Plymouth Barraucda
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #7 on: March 24, 2007 - 08:38:38 PM »
She is in charge of the jack.  :poopoke: :roflsmiley:
Offline 1BADFISH™
« Reply #8 on: March 24, 2007 - 08:43:10 PM »
If rust buildup is giving you a problem heat the nuts with an oxy acetelene torch until they are nice and red, then drench them in the coldest water you have, heat them back up and as soon as they are hot they should turn right off with a socket. I deal with the rust alllllll the time at work... d**n NY and its salt.
Thats a little trick my dad taught me when I was a kid, you need to know these things when you grow up on the rusty east coast.   :bigsmile:
Charlottetown, PE
Offline ChallengerGary
    • Challenger Gary
« Reply #9 on: March 25, 2007 - 07:29:16 AM »
I am waiting for Espo to deliver my rear leaf springs also  :bigsmile:  Plan on dropping the rear end today and taking it apart to detail it up, install new bearings, brake lines, rebuild the brakes and paint the underside of the car while it's out.   :working: :working: :working:
2006 Dodge Ram 1500 Mega Cab 5.7 Hemi
1972 Dodge Demon - "new" project
AND TOO MANY OTHER MOPARS THROUGH MY HANDS TO COUNT
  • Global Moderator
« Reply #10 on: March 25, 2007 - 01:43:21 PM »
Hahaha, it does look that way in th epic BUT...
I worked my butt off on changing those springs.  I did forget to mention that cutting the U bolts is the best way to go.  We tried to get them off w/out cutting them at first too.  Big mistake, LOL.
« Reply #11 on: March 25, 2007 - 02:05:24 PM »
  :iagree:  :iagree:  :iagree:
 Hack-saw them buggers. It makes you feel Sooo much better.  :thumbsup: The threads might even be stretched a tad, so just go with new ones that aren't rusted.
« Reply #12 on: March 25, 2007 - 09:22:47 PM »
Always replace the U bolts , I cut them as well , angle grinders are fast
« Reply #13 on: March 26, 2007 - 08:58:22 PM »
I got out the sawzall and cut the u-bolts tonight.  Could only get to the back half, so now I have 2 J bolts holding the leafspring to the axle LOL  Angle grinder will be out tomorrow.
  • Global Moderator
« Reply #14 on: March 28, 2007 - 03:56:55 PM »
Yeah, I don't know what I was thining trying to get those U bolts off without cutting them.  As MEK said, it sure felt good to cut through them!
