Author Topic: Are 440 and 383 A/C brackets the same?  (Read 1076 times)
Offline AMXguy
« on: March 23, 2007 - 11:54:30 PM »
 Can you use the same A/C compressor brackets for a '70 440 and 383? I've heard 440's are different.
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline farmboy70
Re: Are 440 and 383 A/C brackets the same?
« Reply #1 on: March 24, 2007 - 06:46:48 PM »
No the brackets are different for the block height.
Offline AMXguy
« Reply #2 on: March 24, 2007 - 07:33:05 PM »
That figures, I need one I guess if anyone wants to sell one.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline farmboy70
« Reply #3 on: March 24, 2007 - 07:50:57 PM »
All the brackets? and which 383 or 440?
Offline AMXguy
« Reply #4 on: March 24, 2007 - 09:35:06 PM »
I need the compressor brackets for a 440, if the 383 ones are different.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline ShelbyDogg
« Reply #5 on: March 26, 2007 - 10:09:33 AM »
The brackets are all the same.  The only one different is the extension plate that bolts to the head that the alternator bolt attaches to. It raises the mount point when using a 383 or 400 engine.
Offline Robb
« Reply #6 on: April 03, 2007 - 01:10:51 PM »
The brackets that mount to the front of the block are the same, I agree
HOWEVER:
It was my recent direct experience...  :banghead:      :)
One of the support arms is not the same, and neither is the " L " bracket that mounts to the head (IIRC on mounting spot)
I customized my 383 ones to work though on my 440.  L bracket just needed redrilling and trimming with a grinder, and the support arm I had to cut and weld back together.
anyway...   that was my experience when I pulled the 383 out and swapped in the 440.
« Last Edit: April 03, 2007 - 01:13:14 PM by Robb »
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
