Author Topic: small block intake torque sequence?  (Read 11753 times)
Offline 74 340 4speed
« on: March 24, 2007 - 06:26:51 PM »
Anyone know what the intake manifold torque sequence is for a small block?  :clueless: I've got to take the aluminum Edelbrock intake off the 340 in my Cuda because it is leaking oil around the back of it.  How much do I torque it down to? 25 ft lbs?  I want to be sure I torque it correctly so that I don't damage my intake.  Do you guys recommend using the gaskets or just silicone on the front and back of the block?  The gaskets have pushed out of mine and I was leaning towards using only silicone on these areas.
Andy
1967 Camaro SS: 406 sbc 505 hp/506 ft lbs|4 speed|Posi|3.73s
1969 C/10  350|Turbo 350
1969 Dodge D300 318|4 speed|Dana|4.88s
1972Nova: 350|Turbo 350
1974 'Cuda: 340|4 speed|Dana 60|4.10s|posi
1999 Camaro SS: Auto|Longtube Headers|True Duals|TT2s
2013 Challenger R/T: 6 speed|Hurst with pistol grip|mopar performance exhaust|super track pak
nivvy
Re: small block intake torque sequence?
« Reply #1 on: March 24, 2007 - 06:32:14 PM »
TORQUE SPECS & THREAD SIZE
Camshaft Lockbolt 35 7/16-14
Carburetor to Manifold Nut 7 5/16-24
Clutch Housing Bolt 30 3/8-16
Connecting Rod Nut - Plain 45 3/8-24
Crankshaft Bolt (Vibration Damper) 135 3/4-16
Cylinder Head Bolt 273-318 85 1/2-13
Cylinder Head Bolt 340-360 95 1/2-13
Flywheel Cover Bolt 100 in/lbs 1/4-20
Flywheel Housing to Block Bolt 50
Flywheel to Crankshaft Bolt 55 7/16-20
Fuel Pump to Block 30 3/8-16
Intake Manifold Bolt 35 3/8-16
Main Bearing Cap Bolt 85 1/2-13
Oil Pan Drain Plug 20 1/2-20
Oil Pan Bolt 15 5/16-20
Oil Pump Cover Bolt 95 in/lbs 1/4-20
Oil Pump to Block Bolt 35 3/8-16
Rocker Shaft Bolt 30 3/8-16
Spark Plug 30 14mm
Timing Cover Bolt (cast) 30 3/8-16
Torque Converter to Flexplate Bolt 270 in/lbs 5/16-24
Vibration Damper Pulley Bolt 200 in/lbs 5/16-20
Water Pump to Block Bolt 30 3/8-16
Go here for torque sequence!
http://www.edelbrock.com/automotive_new/misc/tech_center/install/7000/7576.pdf
« Last Edit: March 24, 2007 - 06:44:53 PM by StrOkEr »
Offline ksierens
    • 70 Challenger Resurrection
« Reply #2 on: March 24, 2007 - 06:52:10 PM »
Kurt - SE Michigan
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #3 on: March 24, 2007 - 09:01:47 PM »
I used only silicon on mine with the RPM and my father used only silicon with his performer and neither one of them have leaked yet.  Just make sure there is no oil on the surface before you use it.  The thickness of ours was about 1/2" wide by about 1/4" to 1/2" thick.  It is better for it to squeeze out than for you to have a gap.
Good luck  :2thumbs:
Offline Jacksboys
« Reply #4 on: March 24, 2007 - 09:05:18 PM »
Here is a pic of mine.  My father used an orange colored version which looks better than mine.
Offline PlumCraZRT
« Reply #5 on: March 25, 2007 - 12:35:16 AM »
Permatex orange silicon rocks with the Mopar HP orange engines!  :ylsuper:
mmmmm.... Mopar.... *drool*
