Author Topic: challenger muffler specs  (Read 1153 times)
Offline 70challengerrt
« on: March 25, 2007 - 06:58:12 PM »
Does anyone have the specs of a stock challenger muffler. case size, length, center to offset?
Thanks
Todd
Re: challenger muffler specs
« Reply #1 on: March 25, 2007 - 10:15:58 PM »
Case length 21" diameter 7"  see diagram for offset
« Reply #2 on: March 26, 2007 - 05:06:24 AM »
Maybe I got them mixed up I need the muffler or resinator that is in front of the axle. I want to order stock head pipes and replace my glass packs with warlock mufflers with electric cutouts and I want to make sure they fit where the stock mufflers would fit. I thought the stock were oval case with center inlet and offset outlet but that was a guess. I took out the ones by the gas tank and ran pipe striaght through that part.
« Reply #3 on: March 26, 2007 - 05:12:46 AM »
The mufflers in front of the axle only fit good in the original space. On my car, I bought the date coded repros from Josh's muscle car (logitec) and the inlet and outlet were in the centers. My head pipes are 2 1/2 for my 6 pk engine. They fit right in perfect.
« Reply #4 on: March 26, 2007 - 10:23:58 AM »
Thanks That is what I needed. The warlock mufflers are a little shorter I think so I will just have to add a little pipe to it but the center inlet center outlet is helpful.
Todd
Offline ChallengerGary
    • Challenger Gary
« Reply #5 on: March 26, 2007 - 11:13:17 AM »
FYI - The ones in front of the axles are the Resonators.  The ones under the trunk pan are the mufflers.  Dynomax makes a nice Round can muffler that sounds great when used in the back  :2thumbs:
2006 Dodge Ram 1500 Mega Cab 5.7 Hemi
1972 Dodge Demon - "new" project
AND TOO MANY OTHER MOPARS THROUGH MY HANDS TO COUNT
Offline todd383
  • I'm a llama!
« Reply #6 on: March 29, 2007 - 05:22:49 PM »
Offline 383 SE
« Reply #7 on: March 29, 2007 - 07:20:37 PM »
Did you use the Dynomax mufflers with the stock resonators? How did it sound? My stock mufflers and resonators are to quiet for me.
    • Challenger Gary
« Reply #8 on: March 30, 2007 - 05:22:17 AM »
No, I just used the Dynomax cans in the back - no resonators.  It also makes the underside of the car really clean as well.
« Reply #9 on: March 30, 2007 - 05:56:08 AM »
I suppose you are using the 18" case length Dynomax......I see Magnaflow has basicly the same 18" long 7" round muffler anyone try those?
    • Challenger Gary
« Reply #10 on: March 30, 2007 - 01:34:43 PM »
Yes, it was the 18" ones I used in the back.  Actually have done this on 3 or 4 e-bodies and they look very factory correct if you just take a quick look under there.  Never used the Magnaflow version so can't comment on them.
