Author Topic: 440 starter  (Read 1062 times)
Offline r15303
440 starter
« on: March 25, 2007 - 08:41:26 PM »
Pulled off my 1970 440 6pack starter tonight and the wire connection nuts were metric!   :22yikes:  Didn't expect this.  do I have the wrong starter?  If so, which one should I have?  There is no marking on the one I have.  :clueless:
Re: 440 starter
« Reply #1 on: March 25, 2007 - 08:56:16 PM »
Still should be 1.5 hp for the starter, just a newer year rebuilt I do believe :2thumbs:
Re: 440 starter
« Reply #2 on: March 25, 2007 - 09:19:25 PM »
wel the large nut will be 1/2 " which will work with 13 mm , & the small nut is 1/32 which very few people have a socket for But 9 mm works too
Offline r15303
Re: 440 starter
« Reply #3 on: March 25, 2007 - 10:07:52 PM »
Guys  the nuts are 12mm and 7mm.  Could this be a newer hi torque starter?
Re: 440 starter
« Reply #4 on: March 26, 2007 - 03:05:49 AM »
If it weighs less than 40 pounds, then yes.  :lol:
Offline r15303
Re: 440 starter
« Reply #5 on: March 26, 2007 - 08:32:04 AM »
MEK - Ya,  it is small and weighs way less than 40 pounds!   :bigsmile:  Where can I get the correct starter?  I checked EBay and - no luck.  Thanks
Re: 440 starter
« Reply #6 on: March 26, 2007 - 10:22:10 AM »
any local rebuilder shoudl. be able to supply the HD old style starter
Re: 440 starter
« Reply #7 on: March 26, 2007 - 03:07:48 PM »
I hardly ever see the good old torpedo starter on E-Bay(I just checked). I believe you can get them at a local auto parts store, but they want a core exchange in return, I think. That would be a problem here.  :pullinghair:
Offline PlumCraZRT
Re: 440 starter
« Reply #8 on: March 26, 2007 - 11:44:05 PM »
They probably wont require the core, but they'll charge you for it.  Go to your local junk yard. Starters like those are on everything and then you can use it as a core at a local parts shop and save ~$35.
mmmmm.... Mopar.... *drool*
Offline r15303
Re: 440 starter
« Reply #9 on: March 27, 2007 - 02:08:14 PM »
Thanks  -  Is there a part no. I should be looking for or were all the big block starters the same?  I have a 70 Challenger R/T  440 6 pack
Re: 440 starter
« Reply #10 on: March 27, 2007 - 03:13:00 PM »
I'm sorry I don't have a part number. It should not be hard to find an old starter though. I think any car from the 60's thru early 70's used the same starter, regardless of engine size.
Re: 440 starter
« Reply #11 on: March 27, 2007 - 03:33:33 PM »
all starters are not the same , the HD use a longer body something like 3.5" to 3" light duty
Re: 440 starter
« Reply #12 on: March 27, 2007 - 08:45:56 PM »
The longer 3.5 inch starters will cause havok with headers. Clearance issues.
