Author Topic: Continuing 4 Speed Woes  (Read 871 times)
Offline MoparMatt383
  • Member as of March 2004
« on: March 25, 2007 - 09:08:08 PM »
I just put an 833 in my barracuda.  I dont really know the history on the trans, but I figured I would just put it in for starters to see if it worked as is.  It worked well up until this afternoon.  I had the car out around the city with some highway driving too and it worked fine.  When I got back to my house after my cruise and I went to park it there was terrible grinding when putting it into reverse.  Also when getting into first there was grinding but not as bad.  Once I got it into reverse or first the car moved fine without any noise or grinding.  Also there is grinding and vibrating that can be felt in the clutch pedel at a point of the travel in the pedel when the clutch feels like it is just starting to engage and moving the car.  This leads me to belive that it might not be a trans problem, but something else.  I'm not sure.  Anyway any help would be greatly appreciated.
Thanks,
Matt
Too many projects and nothing gets done.
Offline Carlwalski
Re: Continuing 4 Speed Woes
« Reply #1 on: March 25, 2007 - 09:14:42 PM »
Sounds like the clutch isn't fully disengaging itself perhaps, hence the grinding. Maybe a clutch adjustment. :dunno:
:2cents:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
« Reply #2 on: March 25, 2007 - 09:21:18 PM »
:2cents:
 I agree probably need to reset the clutch adjustment
Offline dtedler
« Reply #3 on: April 05, 2007 - 10:35:21 AM »
Did you add a little grease to your pilot bearing.  Better yet, what are you using for a pilot bearing?  Some the new materials aren't worth the paper that packages them.  I had this problem with my car a few years back.
Offline Stacked440
« Reply #4 on: April 09, 2007 - 08:04:08 PM »
If its grinding in and out of gears, might be the synchronizers for first and reverse? :dunno:
-Kyle-
