Author Topic: Paint Bubbling  (Read 1112 times)
nivvy
Paint Bubbling
« on: March 27, 2007 - 11:21:53 AM »
Well I got my car back in the winter time so now that is summer and the climate is changing it seems like everyday I got out and look at my car i see more and more tiny bubbles coming out of the paint....is this because prep work wasnt done right??? or any experts have any clues.... im pi$$ed .....
Offline mopar_guy
Re: Paint Bubbling
« Reply #1 on: March 27, 2007 - 11:24:54 AM »
im not a paint guru,but i think i could have been the prep work.make them fix it! i would also be very pi$$ed
Offline Wang
  • "just hangin' out"
    • valleyautoworks.net
Re: Paint Bubbling
« Reply #2 on: March 27, 2007 - 11:25:58 AM »
Define bubbling,,, If its bubbles lower on a panel such as behind a wheel,, probably bad mudwork, if they look like little zits more on the upper portion of the car, then it is bad prep under the paint,, between the primer and color.
Hurry,, Duane the tub,,I'm Dwouning....
nivvy
Re: Paint Bubbling
« Reply #3 on: March 27, 2007 - 01:16:17 PM »
Yes it is like zits....and showing up on the roof / doors / different areas of the car etc....  :burnout:
Re: Paint Bubbling
« Reply #4 on: March 27, 2007 - 02:54:13 PM »
How was your car prepped? Acid dipping would cause something like this.
Offline 360 'CUDA
Re: Paint Bubbling
« Reply #5 on: March 27, 2007 - 03:27:14 PM »
I HATE bodyshops!!!!
nivvy
Re: Paint Bubbling
« Reply #6 on: March 27, 2007 - 03:44:24 PM »
no wasnt acid dipped...I dont kno what the heck they did........  :horse:
Offline moper
Re: Paint Bubbling
« Reply #7 on: March 29, 2007 - 10:10:31 AM »
It's a reaction between the paint and substrate. It means they messed up, either by application, or by not removing or sealing something. It will not get better...Only worse.
Offline torredcuda
  • Epping NH joined 11/23/03
Re: Paint Bubbling
« Reply #8 on: March 29, 2007 - 04:25:36 PM »
It could also be solvent popping which is the paint solvents(thinners,reducers) being trapped under layers of paint b/c of not allowing enough time to dry between coats.When it does dry it comes up thru the top layers causing small bubbles.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline moper
Re: Paint Bubbling
« Reply #9 on: March 30, 2007 - 06:20:59 AM »
With the speed some of the work is done at now-a-days things like proper drying time is overlooked. I would think those bubbles would appear sooner tho. I made that mistake once. I sprayed med to heavy coats without enoguh flash time between them. (Always have a clock and thermometer handy in the booth!! :banghead:) It looked great when I rolled it out and removed the masking. The next morning, it looked like the surface of the Moon. :puke:
Offline aussie-e-body
Re: Paint Bubbling
« Reply #10 on: March 30, 2007 - 07:56:33 AM »
these could also be humidity blisters caused by moisture in the air supply.with the warming of the weather the moisture in the paint expands and creates  small blisters.
just my 2c worth
i want it all-i want it yesterday-and i want it for nothing
