Author Topic: Silver Bullitt's progress  (Read 33554 times)
Offline NoMope Greg
Re: Silver Bullitt's progress
« Reply #90 on: August 24, 2009 - 12:39:53 PM »
Looking good, Wade.  Very clean under there.  :2thumbs:
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
« Reply #91 on: August 24, 2009 - 01:13:31 PM »
It does look really nice under there.  Are you leaveing the center section bare or is it painted?  It looks bare to me.  The same for the rear swaybar and brackets.  They look bare steel.
« Reply #92 on: August 24, 2009 - 02:42:55 PM »
There was no evidence these pieces were ever painted so I clear coated...
Found this works good. http://www.eastwood.com/specialty-coatings/clear-coat/diamond-clear-satin-set.html
It's very thin & sprays well, also goes on easily with a sponge brush. The satin finish looks like new steel.
Offline 426HEMI
« Reply #93 on: August 24, 2009 - 03:33:58 PM »
 :2thumbs:  Looks very good and is very inspiring to me to get mine done,   :bigsmile:   :2thumbs:
1970 M46 Barracuda
1998 Dodge Darango
Gordon
« Reply #94 on: September 09, 2009 - 05:15:57 PM »
Do you have any pics of your rear drums before you cleaned them up?  Was there any trace of orange paint on them?   I have an origonal pic of my car that seems to show orange drums.
« Reply #95 on: September 09, 2009 - 07:23:02 PM »
No pictures but the original color, I'm pretty sure, was red not real dark but not bright leaning toward orange maybe & was a lower gloss but not totally flat . This is what I recall & seems that I've read that here some where.  Pose the question to the board & I'm sure someone will have the perfect solution.
Just found this... Article calls it brick red. see page 54
http://books.google.com/books?id=FNfbubrQXC4C&pg=PA54&lpg=PA54&dq=red+brake+drum+challenger&source=bl&ots=14dQnLOVtL&sig=8DvoHNuTRCn577RzQAgc-wPAYEY&hl=en&ei=MTeoSseXJoO0tgfJjs2JCQ&sa=X&oi=book_result&ct=result&resnum=4#v=onepage&q=red%20brake%20drum%20challenger&f=false
Found this pic. that is close if not it.
« Last Edit: September 09, 2009 - 07:43:46 PM by Bullitt- »
« Reply #96 on: October 02, 2009 - 11:52:34 PM »
Well it's been a long few weeks since any real progress was made, heat & humidity finally set in making hanging out in the garage not any fun..  Tinkered with the new exhaust system quite a bit, installed headers, mini starter then got hung up on the header to exhaust connection. Ended up ordering a 180 bend to get 4-45s out of to make the transition. One side done the other may be complete this weekend. While waiting three weeks for the pipe to arrive I tinkered with making a few longer plug wires & some prototype wire looms.
« Last Edit: October 03, 2009 - 12:00:24 AM by Bullitt- »
Offline quapman
    • Auto-Grip on Facebook
« Reply #97 on: October 03, 2009 - 09:01:21 AM »
Looking better & better, Wade.
Is your exhaust pipe regular steel, alumi-coat or stainless?
« Reply #98 on: October 03, 2009 - 09:14:46 AM »
304 Stainless by  Pypes,  ordered through Summit http://www.summitracing.com/parts/PYE-SME11S/, paid  350 for the system 50 for collectors &  Magnaflo 180 shipped for 25
« Last Edit: October 03, 2009 - 09:17:36 AM by Bullitt- »
wagesofsin
« Reply #99 on: October 03, 2009 - 09:21:26 AM »
very nice wade!!!    :droolingbounce:
« Reply #100 on: October 03, 2009 - 04:34:02 PM »
It's looking good.
Can you explain the process you have been using to clean up your bare metal parts?  I've been cleaning up some small brackets with a flap disc on my angle grinder and they are coming out pretty good.  The only thing is that they are coming out pretty shiny.  Are you leaving yours like that or are you dulling them down a little so they are closer to factory appearing?  I found that if you lightly bead blast the parts after they have been sanded smooth, they come out with a matte finish.  Just wondering what you have been doing.  Keep the pics coming!
« Reply #101 on: October 03, 2009 - 04:53:06 PM »
Most of the odd shaped metal such as the shock mounts I have sand blasted then wire brush on a drill.  Some of the smoother parts such as the sway bar I used a DA sander then hand sanded in a circular pattern.   The flat clear darkens the metal a little, looks a lot like the picture you posted of the painted UCAs.
Offline DAYLEY/CHALLENGER
« Reply #102 on: October 03, 2009 - 07:37:04 PM »
Hey Wade.........Looking good..............The heat does seem to  tire us guys out quick.  Fall is comming here now and time to tinker some more.  Keep the progress reports comming.   David :2thumbs: :2thumbs:
Dave or David
« Reply #103 on: October 27, 2009 - 08:25:30 PM »
Wade...your PM box is full. :thumbsup:
« Reply #104 on: October 27, 2009 - 08:50:37 PM »
Flushed a few. Try again
