Author Topic: Silver Bullitt's progress  (Read 33526 times)
Offline 422STROKER
  • Member Since 6/3/06
Re: Silver Bullitt's progress
« Reply #45 on: October 03, 2008 - 07:54:14 PM »
Great job on the bodywork.  I like the stereo stuff too, did you end up getting the 2.0 farad cap?  I've been worried with my small 1/2 farad cap since it discharges itself quickly when the battery is disconnected from it, wonder if it is bad.
Anyways, keep up the great work on that bad boy and you'll be driving soon enough. :2thumbs:
Tom
Tom
« Reply #46 on: October 03, 2008 - 08:00:37 PM »
Yep got the 2.0F....small garbage can... Twas cheeper than most 1.0F units...mine discharges if the battery is down as well.  I been thinking about making a perminent circut that I can push a button & recharge as this is a PITA to deal with otherwise.
Offline DAYLEY/CHALLENGER
« Reply #47 on: October 03, 2008 - 08:06:31 PM »
Hey Wade.  Looks like there will be a lot of noise on the inside......Good stuff.  When will we hear some noise from the power plant?   Like the dogs too.
Dave or David
Offline 422STROKER
« Reply #48 on: October 03, 2008 - 08:52:17 PM »
Thanks, I am mostly concerned since when I re-connect the battery there is usually a good spark jumping to the terminal to feed the cap.  If I pull the fuse for the cap then when I put the fuse in same thing at the fuse.
I'll try and look into this a bit.
Great shot with the dogs.
Tom :2thumbs:
Tom
Offline 422STROKER
« Reply #49 on: October 03, 2008 - 08:56:45 PM »
Doh!  You have to use the resistor to recharge the cap everytime the cap is discharged.  I should have realized that.LOL
Tom
Tom
« Reply #50 on: October 03, 2008 - 09:10:56 PM »
Jest fer you David......I don't have any idea who the redneck is making the commentary.
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://s262.photobucket.com/flash/player.swf?file=http://vid262.photobucket.com/albums/ii100/wbullitt99/repair/18a62718.flv"></embed>
« Reply #51 on: October 03, 2008 - 09:12:30 PM »
Tom
UH Hu..resistor to charge.. the big spark must be normal
« Reply #52 on: October 04, 2008 - 01:27:21 PM »
WADE...............That was wonderful.  I got a good feeling when she fired.  Sounds good too and the music...........playing in the background.......nice touch.  Thanks.   We need to hear from more of our members like this.   I started a thread somewhere here a few months ago but not too many takers.   Anyway......great.   And I know you can't sait to get her on the road.   Looking forward to seeing that too.    David :cooldancing: :cooldancing:
Dave or David
« Reply #53 on: November 12, 2008 - 11:51:39 AM »
Thought I would bump this..........Anymore work done.........Keep up posted.... :working:
Dave or David
« Reply #54 on: March 20, 2009 - 08:52:21 PM »
Did I ever tell you guys about the brake job I started 3 years ago?.......
                                    Then I found CC.Com........
                               :swear: CC>Com.......  :roflsmiley:
  Any who I have my Spring Cleaning & Blasting & Painting all lined up
My Son is home from college  & was a big help wrenching & wranglin the dif & exhaust.......
I of course was like a Hog in Slop
« Reply #55 on: March 20, 2009 - 10:35:50 PM »
Wade...........you are back............Those pieces look like I have seen them before...............Got my oil changed today and here is a couple of the underside of the exhaust.........
Keep the pics comming now that you have some help.........
Dave or David
« Reply #56 on: March 21, 2009 - 02:33:16 PM »
Thanks David,  Who's Exhaust pipes did you use & what are they made of?
« Reply #57 on: March 21, 2009 - 02:55:49 PM »
I know some of you are interested in factory markings so I'm posting these for you & posterity. This is from a '73 Dodge Challenger Ralley 340. Gears are open 3:55 ratio springs are 4-leaf
White paint dobs & the # 31 appears to be white
Also notice the Black anodized pinion snubber bolts, the snubber plate shows silver, not paint but natural.
Dark blue, I'm guessing thread lock, on the studs
Black paint on the hanger
# on the front passenger side ....can't make out the 1st digit  _ 0 1 4
# on the front divers side, upside down & underlined light blue or turquoise , cant make out the 1st digit _ 1 2 J
# on forward divers side spring yellow  last digit obscured  5 9 _
# on rear drivers side spring yellow 1 2 4  and I think the last character is "
Center is a yellow circle with J sideways  on the drivers side a stenceled white R
I cant make out the character but another circle in white may be a G or 6
« Last Edit: March 21, 2009 - 02:58:33 PM by Bullitt- »
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #58 on: March 22, 2009 - 01:52:40 PM »
Very cool factory markings!  :grinyes:
« Reply #59 on: March 22, 2009 - 07:15:41 PM »
Hey Wade....the exhaust is from a local shop here .  I think they are stainless. He supplied the mufflers too and they are supposed to be like Flowmasters.  The tips aren't exactly split likt the orig but for $30 each instead of $125 or so..........I took them............Are you going to mark your parts like the orig when going back together??   If so........many more pics are probably in order.......Good luck..........David
Dave or David
