Author Topic: Gear choice for a 440-727 car.  (Read 10640 times)
Offline MyMopar
Re: Gear choice for a 440-727 car.
« Reply #15 on: March 29, 2007 - 01:24:06 PM »
Old's Cool is correct that gears are torque multipliers.  Also you stated in length what Old's School stated briefly.  If the motor is set-up to run the gear then you will see an increase in MPH and lower et's.  However if the motor can't handle the gear, the mph and et's will suffer.
I know from first hand, I ran a 69 Charger with 440/auto and 3.91's.  The car ran great on the road and track but for some stupid reason I let my neighbor (who was a huge Mopar guy back in the day and still had great knowledge) talk me into 4.30's.  Well guess what, that car lost MPH and et in the qtr BUT gained in the 1/8.   It was a blast at the stop lights though  :burnout:
1969 (OO===]|[===OO)
1973 (OO/=====\OO) <---SOLD
1997 (O|||||O) <---SOLD
Smoke tires, not drugs!
Offline v8440
« Reply #16 on: March 29, 2007 - 05:24:57 PM »
Ok, you win-gears multiply power.
Offline MyMopar
« Reply #17 on: March 30, 2007 - 09:25:12 AM »
There are no winners, gears multiple torque not power. In my Jeep I replaced the 2.72 low gear range with a 4:1, I just increased my rear wheel torque with that gear change.  The same applies to cars doesn't it?
Oh and I never said they multiply power.  :clueless:
Offline Oldschool
  • Member Since 9-05-06
« Reply #18 on: March 30, 2007 - 10:50:11 AM »
Neither did I..    :clueless:   A 500 HP engine will make 500 HP regardless of what gear is behind it.  It doesn't know the difference.  If it also has 500 lb/ft torque, it will also make 500 lb/ft torque regardless of what gear is behind it.  As has been said repeatedly here, "gears multiply torque".  On this point, we all seem to agree. This is the torque delivered to the rear wheels via the assistance of the steeper gear and not an increase in torque output of the engine.  A steeper gear allows the engine to get into it's power band sooner on launch and every subsequent gear change.  Some of the newer computer controlled cars will really slow down of they get a little too much gear.  When you over gear those cars, they get into the overdrive too soon and really lay down on the top end. Our old carb cars respond well to a little more gear.  I ran some calculations yesterday on what would be the optimum gear ratio for the Beast to run the fastest quarter mile.  With my vehicle weight, horsepower, tire size, and a couple of other factors figured in, with No other changes except a ratio change the optimum would be 4:72 to 1. I am currently running a 4:10, so there is room for a quicker ET with only a gear change.  I wouldn't run a 4:72 on the street, but no more than I drive the car, a 4:56 might be in the plan one day.......     :burnout:    :cooldancing:
Ken  --  In Georgia
