Hi all,
I have a '73 Cuda, 340/727 with A/C. The previous owner removed a few items and never put them back in so I'm trying to find out how it should be.
The direction of air flow through heater box is controlled by "air doors" that are moved by a vacuum actuator. I need to find out where the source of the vacuum comes from. I am certain that it comes from the intake manifold but I cannot determine where.
If you have a 72-74 Cuda with a 340 (or other small block) and A/C can you please look under your hood and trace the thin rubber hose that enters the engine bay through the firewall, just to the right of the blower motor and see where it goes to. I would be greatful if you could take photo and post it.
I should also mention that my car has the California Smog gear fitted that feeds off the intake manifold as well.
Thanks in advance, Ed.
