Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Started 499 StROkEr today! Serious Issues
« previous
next »
Print
Pages: [
1
2
Author
Topic: Started 499 StROkEr today! Serious Issues (Read 2018 times)
nivvy
Guest
on:
March 30, 2007 - 02:58:48 PM »
The car started up ok and took a while to warm up...been all winter....well anyway after it got warmed up it reved good and had good oil pressure etc....temp held at 180* and that mysterious ticking sound was gone by the way but man those new roller rockers seem noisy and chattery
anyone elses sound like that
but when disaster happened water started pouring out of the back of the block on both sides
I though it was a head gasket but after several start ups with my buddy I seen that it was coming right out of the freeze plugs in the back of the heads on both heads
what causes this
is this serious
Last Edit: March 30, 2007 - 03:12:45 PM by StrOkEr
Logged
Moparal
Permanent Resident
Re: Started 499 StROkEr today! Serious Issues
Reply #1 on:
March 30, 2007 - 03:07:48 PM »
Your engine froze up over the winter. You didnt have the propper anti freeze mix. Or, you got rotten freeze plugs.
Logged
nivvy
Guest
Reply #2 on:
March 30, 2007 - 03:13:56 PM »
so it is not seriuos...just change the freeze plugs...the water coming out was kinda brown like rust ...??
Last Edit: March 30, 2007 - 03:38:46 PM by StrOkEr
Logged
Moparal
Permanent Resident
Reply #3 on:
March 30, 2007 - 03:43:39 PM »
If you didnt crack the block or valley, you should be ok. Water in the oil? Hope not.
Logged
nivvy
Guest
Reply #4 on:
March 30, 2007 - 06:32:52 PM »
Well I checked the oil on the dipstick and looks like regular oil to me....or should you drain it
why would the block possibly crack
Logged
ksierens
Sr. Member
Reply #5 on:
March 30, 2007 - 06:34:58 PM »
If you didn't have proper protection with antifreeze, and the water in the block freezes, it expands and has to go somewhere so ... crack!
May not be your problem, hopefully it is just bad freeze plugs.
Logged
1970 Triple Black Challenger R/T 440 Six Pack - 4 Speed - 3.55 Dana
Kurt - SE Michigan
nivvy
Guest
Reply #6 on:
March 30, 2007 - 06:43:40 PM »
I really didnt have a cold winter and when I was out working on my car the heat was on ... if the block was cracked would water leak out of the block....the only place the water was coming out was the freeze plugs in the head...
Logged
Moparal
Permanent Resident
Reply #7 on:
March 30, 2007 - 06:52:48 PM »
No water in the oil is a good sign. You may just need to install new freeze plugs. Can be a bugger of a job tho.
Logged
nivvy
Guest
Reply #8 on:
March 30, 2007 - 07:00:19 PM »
yea since there in the back of the head....you pry em out with a screwdriver
Logged
nivvy
Guest
Reply #9 on:
March 30, 2007 - 08:57:15 PM »
After looking at mine they are the crappy steel ones that rot out ...
i need brass ones ... or do they make better stuff now...
Logged
Moparal
Permanent Resident
Reply #10 on:
March 30, 2007 - 09:18:03 PM »
Brass, rubber and steel is all I know of
Logged
nivvy
Guest
Reply #11 on:
March 30, 2007 - 09:32:40 PM »
where do you get the rubber ones
Logged
Moparal
Permanent Resident
Reply #12 on:
March 31, 2007 - 04:47:45 AM »
Rubber ones are easy to do, but dont last as long as steel or brass, most every parts house has them
Logged
nivvy
Guest
Reply #13 on:
March 31, 2007 - 09:49:38 AM »
How the heck do you get those plugs out....
Logged
Oldschool
Administrator
Permanent Resident
Member Since 9-05-06
Reply #14 on:
March 31, 2007 - 10:06:14 AM »
Quote from: StrOkEr on March 31, 2007 - 09:49:38 AM
You are prolly gonna have to pull the heads to do it right. If there is enough room between the back of the heads and the firewall, you might be able to "dig" whats left of the old ones out. But in order to make sure you get the new ones in and correctly seated, you will most likely have to pull the heads and put them on a workbench in order to get them in correctly. That way you can get the hole good and clean so the new ones will seal correctly. As much of a pain as that would be, it's what I would do. That way you know they are in right and you won't have to do it a second time when they fail again.......
Logged
Ken -- In Georgia
Print
Pages: [
1
2
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
