Dodge Ram Diesel Edge Attitude w/Outlook monitor
Author Topic: Dodge Ram Diesel Edge Attitude w/Outlook monitor  (Read 788 times)
Offline Morris'_Mopars
« on: March 31, 2007 - 07:42:27 PM »
[/I had this system on my 2003 Ram and have traded it off on a 2007. The connectors are different on my new truck so I can not use this model. It works great and have had no problems. I paid over $900.00 for this system new. I have everything that it came with new. Asking $600.00
KEY FEATURES:
â?¢ 5 on-the-fly Adjustable Power Levels
â?¢ Touch-of-a-Button Control
â?¢ Additional 100 HP and 250 ft lb Torque
â?¢ Increases Fuel Economy*
â?¢ Greatly Improves Driveability
â?¢ Enhances Towing Performance
â?¢ Excellent Throttle Response
â?¢ Includes Safety Features
The Edge Juice/Attitude is a highly sophisticated package capable of improving your Dodgeâ??s driveability, towing, mileage and, most importantly, POWER.
Using factory-style connections in just thirty minutes you can add five levels of adjustable power ranging from 25 to 100 horsepower â?? and increase torque up to 250 ft. lbs. The Juice greatly improves responsiveness and driveability, while at the same time increasing fuel economy.
When used in conjunction with the Attitude monitor you can control the five power levels on-the-fly from inside your truck. The Attitude displays all the information a complete set of gauges would and will automatically monitor and display exhaust gas temperature (EGT), turbo boost and transmission slip and de-fuel the engine to prevent excessive EGT, boost levels or transmission slippage. It also displays 0 â?? 60 times, quarter mile times and actual speed if you are using non-stock tires as well as a host of other parameters.
The following power gains are representative of an actual test vehicle. These gains were measured on a SuperFlow Dyno at an altitude of 4400 ft above sea level, and represent power delivered to the rear wheels of the test truck. The only modification made to the test truck was the addition of the Edge Juice module. Power gains may vary based on vehicle and geographical location.
Level 0: Stock
Level 1: 25 Horsepower - 80 Foot Pounds of Torque
Level 2: 40 Horsepower - 120 Foot Pounds of Torque
Level 3: 60 Horsepower - 150 Foot Pounds of Torque
Level 4: 80 Horsepower - 200 Foot Pounds of Torque
Level 5: 100 Horsepower - 250 Foot Pounds of Torque
Gain up to 150 HP and 350 Torque with hot unlock code**
Imagine, within minutes you get incredible power gains, an increase in mileage and the equivalent of a complete set of gauges with one simple installation!
The Juice communicates directly with the engineâ??s ECM, from which it receives vital engine and fuel system information. This enables the Juice to provide smooth and precise power in real time under any driving condition.
Your Attitude monitor allows you to monitor the performance of your engineâ??s vital engine components and output values. The following parameters can be displayed on the main Attitude screen (maximum 4 at one time):
â?¢ Backdown %
â?¢ EGT (exhaust gas temp)
â?¢ Engine Load %
â?¢ RPM
â?¢ Speed MPH
â?¢ Throttle position
â?¢ Transmission Lock
â?¢ Transmission Slip
â?¢ Intake Temperature
â?¢ Boost
That Attitude can sound an alert when certain engine parameter levels are met. The following alerts are available:
â?¢ EGT
â?¢ Boost
â?¢ Engine Temp
â?¢ Speed
Keep track of your performance by recording maximum/minimum for a variety of parameters including:
â?¢ 0-60 times
� ¼ mile times
The Juice alone provides the following power gains with toggle switch:
Level 3: 80 Horsepower - 200 Foot Pounds of Torque
*Increase in fuel efficiency varies based on driving style
**To get the unlock code you must complete a waiver and pay an additional fee. Both the waiver and pricing information are located under product updates. Legal in California only for racing vehicles which may never be used upon a highway.b]
Morris' Mopars LLC
Raymond, Illinois
Mopar performance at affordable prices.
