Author Topic: ITS ALIVE!!!  (Read 497 times)
Offline Stacked440
ITS ALIVE!!!
« on: April 01, 2007 - 07:40:29 PM »
Fired up the 440 tonight! runs good but the rear side freeze plugs leak antifreeze.  Anyone got a trick to taking them out and putting them back in while the motor is in the car?
-Kyle-
nivvy
Re: ITS ALIVE!!!
« Reply #1 on: April 01, 2007 - 07:44:49 PM »
Holy heck..you have the same problem as me.....mine are leaking from behind the heads....  :burnout:
Offline moper
Re: ITS ALIVE!!!
« Reply #2 on: April 03, 2007 - 10:01:43 AM »
Did the ebay vender have more than one set for sale?
What is with these cheap SOBs... :banghead:
Offline F N Cuda
  • Hell Yes I Streetrace!
Re: ITS ALIVE!!!
« Reply #3 on: April 03, 2007 - 10:17:38 AM »
Someone just described a method on how he got out freeze plugs out in the rear. He dremeled a slot in it and pried it out then was gonna do magic to install the new ones or use the rubber expansion plugs that just tighten up with a wrench. I did this on a Ford Ranger behind the exhaust manifolds and it worked out perfectly, I'd do it that way again (expansion plugs came from Kragen).
Got Fatties?
Offline F N Cuda
Re: ITS ALIVE!!!
« Reply #4 on: April 03, 2007 - 10:21:51 AM »
Just saw the tips again, it was Strokers post.
Got Fatties?
