Author Topic: Wht size tires for new Magnums?  (Read 762 times)
Offline dwbiggs
« on: April 02, 2007 - 09:16:30 AM »
Bought a set of Magnums for my Challenger and need to decide on tires. Right now I have a set of aftermarket 15x7's with 255-60 on back and 235-60 up front. The Magnums will be 15x8 in back and 15x7 up front. Was thinking about going 275 and 245...will 245's clear up front or should I stick with 235? Will 275's fit in rear with 4.5" back spacing?
Dan
Offline vinb
Re: Wht size tires for new Magnums?
« Reply #1 on: April 02, 2007 - 04:43:37 PM »
I have 225/70/15 front and 275/60/15 rear.. no clearance problems.. On a Cuda.....
« Reply #2 on: April 03, 2007 - 04:29:22 AM »
A 245 is on 10mm wider than a 235, so you are adding an extra 1/4" of rubber per side. I don't see why that would be a problem.
I seem to recall reading onanother site where some one had put 255 on the front of their car without any problems, but backspacing selection was of primo importance.
