Author Topic: 6 pack installation  (Read 681 times)
Offline cudamanpaul
6 pack installation
« on: April 03, 2007 - 09:25:13 AM »
I recently found a pretty much new six pack my father had laying on a shelf in our office, and i decided to put it to some good use and throw it on my cuda. So my question is, How much of a pain in the ass is it going to install and what all would be required? Does it take a different intake gasket or just a regular one? All the throttle linkage is there so thats a plus.
Paul
72 Cuda-Show car, 340 stroker with 150 shot of N2o
66 Charger-Full Frame Off restoration. All numbers matching 383 with 31,000 Original miles.
68 Dart-Drag only Monster. full suspension, 580ci of fury. (940 RWHP- 890 RWTQ)
Re: 6 pack installation
« Reply #1 on: April 03, 2007 - 09:37:11 AM »
assuming it is a big block/ 440  system use the 1215 FelPro intake gasket set & do up the 8 bolts that hold the intake down
« Reply #2 on: April 03, 2007 - 09:39:21 AM »
if it is a rare 383/400 low deck use the 1214 intake gasket
if it is a small block system you will have to drain the coolant & change the gaskets , definatly a more difficult install
Offline cudamanpaul
« Reply #3 on: April 03, 2007 - 10:22:06 AM »
yeah, its the small block system i believe. not exactly sure, but assuming it was in a box labeled cuda, im assuming its for the 340. here is a picture of it.
« Reply #4 on: April 03, 2007 - 10:24:33 AM »
doesn`t look like a small block system , no end rails on the manifold to seal to the block
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #5 on: April 03, 2007 - 10:30:51 AM »
It's for a big block. There is no location for the thermostat housing on that one in the front of the intake.
1996 Dodge Viper GTS Coupe
Offline cudamanpaul
« Reply #6 on: April 03, 2007 - 10:33:32 AM »
AHHHHH..i see..I need to learn my mopar parts. All my motor knowledge is in LS1 and LS2's....Well, back on the shelf it goes until i get the 440 up and going. Thanks for the help guys!
Paul
