Author Topic: Gas tank brace  (Read 1122 times)
Offline A110235
  • '71 Challenger JH23G1B
Gas tank brace
« on: April 04, 2007 - 04:23:25 PM »
Hi everyone.  I am getting ready to weld in my gas tank braces.  For the life of me I can't find where I wrote down how far they are supposed to be spaced from center to center.  And I also don't recall if they are spaced equally from the center line of the car.  If someone could help me out with some measurements I would really appreciate it.  Thanks!
Kyle
Nashville, TN         Member since October 09, 2004
Offline 4Cruizn
  • HEMI FISH
Re: Gas tank brace
« Reply #1 on: April 04, 2007 - 08:22:15 PM »
I guess I'm not sure what we're talking about.  I don't think they were welded in unless the challenger is different?
:clueless:
Offline A110235
Re: Gas tank brace
« Reply #2 on: April 04, 2007 - 08:40:13 PM »
I think that they are supposed to be welded in.  When I got my car my trunk was pretty much non-existent.  The braces are the two pieces that are circled in red.  They weld in underneath the trunk floor at approximately where the blue lines are located.  The gas tank is pressed up against them and the tank is held in place with two gas tank straps.
Offline A110235
Re: Gas tank brace
« Reply #3 on: April 05, 2007 - 04:47:49 PM »
Maybe I'm not explaining what I need well enough.  Could someone please use a tape measure and measure the distance between their gas tank straps on their Challenger?
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
Re: Gas tank brace
« Reply #4 on: April 05, 2007 - 04:54:42 PM »
I got 10" center to center.
Dave  :wave:
Worlds first e-body trailer.    Severna Park, Maryland
Offline ksierens
    • 70 Challenger Resurrection
Re: Gas tank brace
« Reply #5 on: April 05, 2007 - 05:03:54 PM »
I've got 10 1/8"
Kurt - SE Michigan
Offline A110235
Re: Gas tank brace
« Reply #6 on: April 05, 2007 - 05:09:19 PM »
Thanks guys, I appreciate it!   :thumbsup:
Offline purple1
Re: Gas tank brace
« Reply #7 on: April 05, 2007 - 05:13:49 PM »
Looked again. Used my glasses this time.   :22yikes: Still 10". This is my trailer so I figured it may be off a little. Then I crawled under my orange car that has no tank in it now, and it was 9 7/8". So I would still go with 10".
Dave  :wave:
Offline ShelbyDogg
Re: Gas tank brace
« Reply #8 on: April 05, 2007 - 05:36:28 PM »
I used my gas tank to line up those braces.   Think about it, if everyone tells you 10" but your new tank smehow has 11" grooves, it's not going to fit when it's time to put it in.   Use your new tank, strapped to the braces and straps to line everything up.
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
Re: Gas tank brace
« Reply #9 on: April 05, 2007 - 06:16:01 PM »
10" CL from brace to brace is what I have set every ebody trunk floor brace to and have had no problems with tank alignment. But if in doubt, do as Shelbydog wrote and double check tank fit.
Measure twice and cut once or is it measure once and cut twice...darn cut it three times and still too short. :2thumbs:
Cant kill the mean and ugly. Only the good die young...I plan to be here a while!!
Offline A110235
Re: Gas tank brace
« Reply #10 on: April 05, 2007 - 09:14:40 PM »
That is the story of my life  :lol:
Shelbydogg has a good point though.  I am buying all my sheet metal as I go along though, I didn't plan on getting the tank till closer to the end of the resto.  I am sure today will be yet another day I reflect back upon and think, "damn, I should have done that differently!"  Thanks again everyone.   :cheers:
Kyle
Offline ShelbyDogg
Re: Gas tank brace
« Reply #11 on: April 05, 2007 - 09:39:19 PM »
And if you have your tank strapped onto the braces, you can get the tank positioned front to back too.    Then no surprises later.
