Author Topic: 70 Challenger Wiper Motor  (Read 5776 times)
Offline papamopar70
« on: April 04, 2007 - 05:30:23 PM »
Sorry no hugh pics this time round, I'll try to get it right later. Right now I've got a little issue with my wiper motor. 1970 Challenger, 3 speed/variable speed motor.  The wipers failed to "park", so I do a little repair work and now they will not turn off. So much for my abilities. So I'm on the hunt for either another motor or rebuilt the one I have. I've located one on ebay, looks identical; however the part # is 3799120 and the part number on mine is 2926919. Any assistance with cross reference on the numbers greatly appreciated. Tks   Papa 70
Re: 70 Challenger Wiper Motor
« Reply #1 on: April 04, 2007 - 05:57:26 PM »
are you trying to stay concourse are just concerned that the part is wrong?   I can't help you with the part number but there are rebuilt OE's available at most local parts stores.
edit:  Napa lists 3-speed motor for my '73  only 2-speed for a '70 don't know what the difference would be
Offline papamopar70
« Reply #2 on: April 04, 2007 - 05:58:18 PM »
I've tried NAPA without any luck. Year One does list them for big dollars, but it's always a possibility. I'll try to keep the numbers correct; however it's not a priority so if any part stores may stock the item that would work. Tks for the reply.  Papa 70 :canada:
1970 and 71 3 speed are unfortunately unique. There's no problem getting a 72-74 3 speed. I'm leaning toward the rebuild if I can find a qualified place. Tks for the info guys
« Last Edit: April 04, 2007 - 06:41:50 PM by papamopar70 »
« Reply #3 on: April 04, 2007 - 06:05:39 PM »
I just bought a 3 spd yesterday on the bay. It was dated for a 74, but it was NOS and 67 bucks shipped in the original box. I was told there's a clock to adust for like a bodies, e bodies and c bodies. The 4 prong plug, you just put them like whats on yours.
Everything works but the park? :dunno: Sure it's not the switch or the dash ground?
« Reply #4 on: April 04, 2007 - 06:11:10 PM »
some stuff to chew on if you want to try & repair your own
Offline PlumCrazy
« Reply #5 on: April 04, 2007 - 08:30:20 PM »
'70 and 71 motors were 3431077, the later motors have a different size crank stud on them and require modification to fit the 70-71 cranks.
Offline papamopar70
« Reply #6 on: April 05, 2007 - 05:27:25 PM »
Thanks for the spec sheet, I did attempt to "monkey" with it somewhat, enough to break a wire on the gear backing. No problem resoldering it. I tried CarQuest with no luck. Lots of 72-74, no 70-71. So it's either rebuild or watch our favorite source for parts, the 'bay. Tks guys     Papa 70
Wow,  I didn't have any idea these rebuild places existed. Not cheap, but definately worth the money getting the rebuild. I see the one I presently have is from a C Body.  Changing that to an E body is worth the money itself. Once again, Thank you!!   Papa
« Last Edit: April 05, 2007 - 08:28:34 PM by papamopar70 »
Offline ksierens
    • 70 Challenger Resurrection
« Reply #7 on: April 05, 2007 - 06:10:39 PM »
Here is a source for you:
http://wiperman.homestead.com/
Kurt - SE Michigan
Offline FY1 RT SE
« Reply #8 on: April 05, 2007 - 07:16:05 PM »
If you are going to spend any money getting yours rebuilt, go with the best.
http://www.julesdaddio.com/index.html
