fuel gauge not working
Author Topic: fuel gauge not working  (Read 1798 times)
Offline 73cuda383
« on: October 21, 2003 - 01:06:17 PM »
What are the most likely proplems and solutions to make my fuel gauge work again?
« Last Edit: October 21, 2003 - 02:26:39 PM by 73cuda383 »
Offline Bart
Re:fuel gauge not working
« Reply #1 on: October 21, 2003 - 04:49:41 PM »
Sending unit
1970 Cuda 383
2008 Titan
2010 G37s
1996 Advantage Victory 27 502ci
2013 HD Roadking
« Reply #2 on: October 21, 2003 - 05:32:45 PM »
 :( Most likely, it's the sending unit. There is hope that maybe it's just the ground strap connected to it. Maybe it isn't making a solid ground connection anymore. Other than those 2, you are left with the gauge itself, or the wiring. Have you ever had the sending unit out before? Chances are, it might be a rust bucket. These are a cheap fix, thankfully. Let us know if you find anything out.
« Reply #3 on: October 22, 2003 - 03:28:54 AM »
could be the voltage regulator on the dash as well but the temp & oil pressure would quit too
Offline oldvamoparfan
  • MOPAR; The only way to go!!!!!!!
« Reply #4 on: October 22, 2003 - 03:19:20 PM »
Take the wire off the sender & connect directly to a good ground.  This should make the gauge read full.  Also, you could look a the lead w/ a voltmeter to see if voltage is there.  If not, go back to the gauge itself & see if voltage there.  Ign sw must be on for this test.  Ovmf
'72 Challenger 360,  '05 Dakota,   04 Town & Country,   '82 Yamaha 650 Maxim
